1985 Ford 1710 Fuel in Crankcase
   / 1985 Ford 1710 Fuel in Crankcase #1
branch92
ford 1710
hello
i have a 1985 ford 1710 the a 3 cyl diesel. over the weekend i was running the tractor when i saw oil start to come out of the crankcase/ blowby vent. i shut the tractor down immediately. i then pulled the dip stick and it is FULL... very full... gave it the old lick test and it tastes heavily of fuel. on top of that the oil is super runny now like i would compare it to near water. oil is all black. no frothiness to it. wondering which route to go next ? is the injection pump shot ? or is there something internal that i just to fix? unknow amount of hours.
   / 1985 Ford 1710 Fuel in Crankcase #2
If u have a torque wrench, figure out the size (17mm?) and retorque the top nuts, where the inj lines hook up, to 35 ftlbs..
THATS for the pump that has the steel lines that come straight up..
If they come off the pump in a circle, the front seal has “let go” and the pump needs to come off to change the seal.
not sure i follow completely. i do have a torque wrench and i do believe its steel lines that come straight up. ill snap a pic tonight... assuming to pull pump its set the timing and go from there ? pics to follow later...
   / 1985 Ford 1710 Fuel in Crankcase #4
I sounds as if it’s a PFR pump.??
U need to remove the steel lines from the pump.. USE THE 2 WRENCH METHOD.!!
Remove 1 then 3 and come back and get #2.. it might be easier..
Then torque the top nuts on the pump..
Hopefully you’ll get a smidge of a turn on the top nuts..
There’s a metal to metal seal along with a small copper gasket that seals the fuel from the oil..
Did u look to see if there’s a supply pump on the engine..?
   / 1985 Ford 1710 Fuel in Crankcase #5
If it’s easier, u can send some pictures to my home email.. it’s my screen name ataoldotcom..
   / 1985 Ford 1710 Fuel in Crankcase #6
If it is indeed a PFR pump and u have to remove it for repair, don’t waste your time trying to time it.. it’s timed with shims under the pump base.. the shims will either stick to the bottom of the pump or to its mounting base.
1995 Ford F-800 Water Truck (A50860)
1995 Ford F-800...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
19 Monitors (A48083)
2016 International ProStar T/A Sleeper Truck Tract (A50860)
2016 International...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
Miller Millermatic 130 XP Welding Machine (A50860)
Miller Millermatic...
