Dadnatron
Veteran Member
I have a 2001 Chevy Tahoe with just over 200K miles on it. Its had some intermittent work, but biggest is we just overhauled the transmission. It has been running very well, and we wanted to just keep it as a spare/farm type vehicle. My wife loves it and when we looked at getting a new one as a replacement, they have completely screwed up the seats as they fold. The Tahoe used to be a large UTILITY vehicle with everything in back folding flat and closed. EXCELLENT design. Now, it is essentially useless and appears to merely be made as a people mover.
Anyway...
Given the above, we want to keep it around as much as possible.
So, about a month ago, the AC goes out and the AC pump is making a horrible racket. You can tell it is bad. I took it in to get an estimate on replacement, and they proceeded to tell me they recommended changing out the entire system, dryer, condensor, and pump because its likely that 'pieces' of the compressor fan have gone throughout the system and ruined it all. The estimate was around $2800 and it just really isn't worth that to me. HOWEVER, I'm moderately mechanical and after checking around, I can get a new/rebuilt pump for $160 or so. So I thought I would give it a try, and have watched a couple YouTube videos which make me believe it is within my ability.
My question really is... should I go ahead and change out the dryer and condenser as well? I KNOW the main problem is the compressor as there is a racket when turning on the AC which stops when turning it off. I do know that there is a small leak in the charging tube/orifice as I can see leak detector bubble out a bit when I initially tried to charge it. After charging it was when the compressor began kicking on with the horrible racket.
Are there any tips you would recommend? This is the video I watched... It is for a 2000 1500 truck, but I believe they have the same setup.
Anyway...
