2003 BX22 Suddenly the steering quit working?
   / 2003 BX22 Suddenly the steering quit working? #1
SUPERNUG
Bronze Member
MID MICHIGAN
BX22
My steering suddenly quit on my bx22. I can pretty much keep turning the steering wheel and the wheels don't turn. Any suggestions?
   / 2003 BX22 Suddenly the steering quit working? #2
Been there. Common BX problem. Center o-ring in steering cylinder is flat-spotted allowing hyd. fluid to just run through. Cylinder needs to be rebuilt or replaced. Do a search and you'll find bunches of discussions.
   / 2003 BX22 Suddenly the steering quit working? #3
I had the same issue with my 2002 BX22. Fortunately, mine was still under warranty. As mentioned, should be many threads on this.
Terry
Went out today to figure out how to fix it and it is working fine now. No idea when it will quit again. I will need to get it fixed before the snow flies as I will need it to keep the drive clean.
10-16.5 SKS1 Tires (A45788)
10-16.5 SKS1 Tires...
Trioliet 1200 Solomixer (A45788)
Trioliet 1200...
2012 FREIGHTLINER CORONADO 122 SD (A45333)
2012 FREIGHTLINER...
JCB  950 MAST FORKLIFT (A45046)
JCB 950 MAST...
377160 (A44391)
377160 (A44391)
Lexion Corn Head Parts (A39855)
Lexion Corn Head...
