2004 power stroke 236000 mi any advise
   / 2004 power stroke 236000 mi any advise #11
any legality issues with dpf delete as there ?was? with egr delete on 6-ohs
   / 2004 power stroke 236000 mi any advise #12
Offroad/racing only
   / 2004 power stroke 236000 mi any advise #13
It's tough to find a shop that'll do it but it's not hard to find someone that does it on the hush hush. SC doesn't have yearly inspections either so that helps.
   / 2004 power stroke 236000 mi any advise #14
I got two well known shops within 20 miles that will do whatever you want as long as long as you can write the check.
I do all my own work.
Chris
   / 2004 power stroke 236000 mi any advise #15
I got two well known shops within 20 miles that will do whatever you want as long as long as you can write the check. I do all my own work. Chris
How much do they charge? Depends on what you have done I guess?
   / 2004 power stroke 236000 mi any advise #16
If you go for an 08-10 6.4 do the dpf delete. Its an awesome motor with a ton of power. I have a 2010 with the dpf delete chipped and i get awesome mileage huge power, very reliable.
   / 2004 power stroke 236000 mi any advise #17
They are very reasonable. I know a couple Dmax guys that had the EGR removed and a 50HP tow program installed. Under $400.
Chris
   / 2004 power stroke 236000 mi any advise #18
They are very reasonable. I know a couple Dmax guys that had the EGR removed and a 50HP tow program installed. Under $400. Chris
Wow that is a good price to bulletproof an engine. I'm not sure what my friend paid to have his 6.4 done but it really woke up that truck and the mileage went way up. I've even heard guys who owned 6.4's with the delete say they preferred it over the 6.7 after owning both.
   / 2004 power stroke 236000 mi any advise #19
Yes, the 6.4 with the deletes is a great platform and the Torque Shift can handle it without any mods.
Chris
   / 2004 power stroke 236000 mi any advise #20
Yes, the 6.4 with the deletes is a great platform and the Torque Shift can handle it without any mods. Chris
Yep. In surprised the Torque Shift doesn't get the praise that the Allison gets. The Allison is great in stock form but you can destroy one easily when you start modding a Duramax.
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A55315)
2016 RAM 5500...
3650 (A47477)
3650 (A47477)
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
Horse Weathervane (A55853)
Horse Weathervane...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
