PatScrum
A friend and I have been racking our brains over a rear drive problem on my ToolCat serial number 424711882, so I know it is a B series. Before I got it, they took it to a dealer where they replaced the hydraulic filters and both rear motors. When it was returned it ran fine for roughly 100 hours. After investing the money they did into the Tool Cat the person sold it to me. They were happy to see it go after battling with it. The manual for the filters says 50 hours when you first get the machine then 250 hours there after. So, the filters should have roughly 150 hours to go. The fluid does have a very slight grey tint to it. (concerning yes)
The symptoms are as such, It will intermittently lock the rear wheels up and code 40-51. When it allows the machine to move without coding, you can tell the rear wheels have a drag to them. When you turn the steering (in two wheel steer) it will lock up the inside rear wheel but allow the rear outside wheel to spin free but in a reverse direction. To add a bit of confusion to the problem, rarely it will work perfectly fine for at most 5 minutes then code 40-51 and back to the cycle of problems again. We also did the 4 wheel alignment. Put it in 4 wheel steer and get the green light for the rear. Put it in 2 wheel steer and get the light. Then go forward about 6 feet then go backwards. It took several attempts to complete as the code kept stopping the machine do to the wheel drag.
We've tested the wiring through the harness, using the wiring diagram from the book. We've traced all the hydraulic lines from the breaking system. It is a perplexing way to do the breaks/differential lock. The differential lock solenoid is the Positive pressure and there's a return line going to a break solenoid labeled as the Brake. This is from the hydraulic schematic in the manual. Both solenoids test good with an oms meter.
A question for the hydraulics, how would we test the line pressure to the rear? The book only describes a flow meter. Do we have to put a T in the line and pressure test it? We couldn't find a port to directly connect to.
I'm thinking the differential lock it not happy, while my buddy is thinking the brake system isn't happy. Either way before we tackle this again next weekend I was hoping someone might have some ideas. I have to say this machine is designed in a bizarre way. The manual is a train wreck. It tells you to go to a page, that page say go to this page, then to that page. 2 to 3 hops around the book you get to where you want to be. Problem for me is i read every page so it's several minutes before I land on the target.
Thank you for any input!
