2005 Jinma 354 First Oil Change for me, any tips
   / 2005 Jinma 354 First Oil Change for me, any tips #1
DonRina
Bronze Member
Vancouver Island
Jinma 354
Well it’s time for that first engine oil change for my Jinma 354 with the three cylinder engine so I’m looking for any tips for the procedure/oil and parts. I’m thinking starting her up and running to temperature and draining the oil oil as per usual. Replace the oil filter, check drain plug sealing ring (copper washer ?) and fill to full level. Restart and let run for a minute, shut down and check for leaks and oil level.
For parts: oil Rotella 15/40 T4, oil filter no idea…looks Chinese any local filters which could be used? Install new copper sealing washer…diameter?
Also should install a new fuel filter but need replacement numbers, I think someone mentioned Napa filters but I haven’t found that thread again.
Don B
   / 2005 Jinma 354 First Oil Change for me, any tips #2
Don B
Here’s a cross reference for your tractor to Wix filters:
   / 2005 Jinma 354 First Oil Change for me, any tips #3
I have the 4-cylinder but my oil filter is a Fram PH8A, which I can get at any Walmart, as befits the heritage of the tractor.
The only thing tricky on mine is that the bracket for the FEL is close to the drain plug and it's hard to get a funnel in there without getting oil all over the bracket.
I think you've covered everything. If you have compression release, I like to use that until the oil light goes out before starting.
Change the injector oil at the same time. SAE30, lawnmower oil.
Thanks much! Any method to changing the injector oil? Kinda new to diesels.
   / 2005 Jinma 354 First Oil Change for me, any tips #7
Injector oil????
   / 2005 Jinma 354 First Oil Change for me, any tips #8
   / 2005 Jinma 354 First Oil Change for me, any tips #9
Also:
   / 2005 Jinma 354 First Oil Change for me, any tips #10
This must be unique to Jinma machines? I certainly don’t have that option on my Kubota.
2024 Ford F-250 4x4 Pickup Truck (A43947)
2024 Ford F-250...
DESCRIPTION & ANNOUNCEMENTS (A43001)
DESCRIPTION &...
Portable Restroom T/A Trailer with Trash Storage Compartment (A41853)
Portable Restroom...
2017 TAKEUCHI TB240 HYDRAULIC EXCAVATOR SN:124002484 powered by diesel engine, equipped with Cab, (A40020)
2017 TAKEUCHI...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A37762)
2019 FREIGHTLINER...
Caterpillar 928G Articulated Wheel Loader (A41853)
Caterpillar 928G...
