2007 l3400 hst transmission leak.
/ 2007 l3400 hst transmission leak. #1
NB Canada
L3400 Hst
Leakage is in the HST valve area. It is not severe yet but starting to drip on the garage floor after usage. I am now trying to locate the cause. I have taken the bodywork around the area off and will clean the transmission case. The area in question is basically under the floorboards. The valve case is a couple inches wide and sandwiched between the clutch case and the mid case, or just forward of the fluid level window. This window is not the source of the problem. I have a parts manual which is very helpful with its diagrams. I also have the WSM but it appears that the info provided is related to the manual transmission, not the HST as it should. I would appreciate any comments or suggestions that may help me move this issue forward. Thanks. C.
/ 2007 l3400 hst transmission leak. #2
I'd look to tighten things. Of course, tighten to spec. When things are cleaned up it should become more obvious where the leak(s) is occurring, so maybe wait before you get a better view (unless you want to swing your wrenches a bunch- tighten everything in sight:)).
I got it all cleaned up and minimally reassembled for operation. I suspect that the leak emanates from the casing seal/gaskets but I will monitor before I tighten anything. Not much room to get a torque wrench on those 6 stud nuts. I would appreciate any response as to what type of torque wrench/accessories is commonly used for tight spots. Thanks.
/ 2007 l3400 hst transmission leak. #4
Yeah, reaching into high and out of the way places is nearly impossible to get a proper torque on. All I can offer is that crows-feet can work in some cases where a socket won't fit: assumes, of course, that you angle enough to swing the torque wrench.
