2009 3038e forward pedal won't budge
   / 2009 3038e forward pedal won't budge #1
ericstac
Fort Bend Co, Texas
I have a 2009 JD 3038e and for a while now the forward pedal won't go in.. it feels like its under pressure sort of, i can squeeze it in a little and its enough to drive forward but at a slow rate compared to the way it should. The rear pedal is freely moving and working as is. I check the hydraulic fluid by the rear of the seat and it was normal level.
What else could this be?
   / 2009 3038e forward pedal won't budge #2
Foreign object wedged in there, lack of lubrication on the pivot point, bent linkage....a whole plethora of things.
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
2013 Ford F-250 Ext. Cab Pickup Truck (A55852)
2013 Ford F-250...
UNUSED FUTURE HYD AUGER (A57193)
UNUSED FUTURE HYD...
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A57193)
UNUSED LANDHERO...
