2013 Tundra oil change interval
   / 2013 Tundra oil change interval #61
Sorry, but I have to disagree. You wrote as if engine maker's were quality constrained by spin on filter companies. Not true at all.
Engine makers are "in the drivers seat" to build an over pressure relief and/or anti-drain back valve in their engine if they want to. It's totally up to them to spec a filter with or without those features. They can also spec whatever requirement they want and let the filter companies bid on it.
I had a vehicle with the pressure bypass built in, so the spec'd filters without it. The engine had a known history of the bypass not being reliable.
At least with a filter you can screw on a new one if there's a problem.
Filters are an off the shelf product. Most are used in a wide range of engines (and brands). For decades designers just pick the size that fits in the allocated space.
   / 2013 Tundra oil change interval #62
Dodge recommends 16,000 km between changes (10k miles) in the 5.7 Hemi, and that's on 5w20 dino oil. Not happening with me, I change it every 8,000 km (5000 miles) and it's plenty dirty enough for me. Oil and filters are cheap relatively speaking. Most of my miles are highway, very little idling time.
Sean
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
2015 Ford F550 Bucket Truck - Versalift VST47 Boom - Powerstroke Diesel - Automatic - 4X4 (A55302)
2015 Ford F550...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
