Not if the gauge is reading empty. It will tho if the cause of a non-registering gauge is a bad ground as the fuel pump need a ground to run. Turn the key on and put your ear up to the filler neck and you should be able to hear the fuel pump cycling when you turn the ignition on............Mike
