nebraskasparks
- Joined
- Jun 4, 2010
- Messages
- 258
- Location
- Northern Illiniois
- Tractor
- 2010 Kubota L5740 HST and JD X734
Traded 2009 JD X500 for new Simplicity Prestige due to Suspension brackets and bolts on 54 inch Deck on JD X500 replaced for third time. Plastic hood on JD developed cracks. Prestige is metal. Love the ride and power steering with the Prestige. Has a slight horsepower increase than JD with similar K72 transmission. No problem cutting up hill while towing DR leaf and grass collector. JD was the same. Plenty of power and traction with both tractors.The cut of the Simplicity is definitely a step up from X500. 52 inch welded deck built very strong and operates at higher speed resulting in finer cut. Break in issues. Rattling sound when brake is released...warranty replaced belt and adjustments made. Quieter now. Throttle came out of dash at 10 hours as overcenter clips not installed properly. Warranty took care of this also. Not off to a smooth start. Anything else I need to know? If these are the only two fixes...should be a good mower.
