2023 John Deere ZTrack Starting Issue
   / 2023 John Deere ZTrack Starting Issue #1
saxon11
Bronze Member
Minnesota
TYM T474
Was mowing for about 15 min, had to stop to mower to move some limbs. I had turned it off. Went to turn the key, and starter does not engage. The digital display looks fine. I made sure brake was on, handles out, and blad turned off and still no turning over. I had driven though some wet grass, maybe 1 inch of water, but cant image that did any damage. Thougths or suggestions?
   / 2023 John Deere ZTrack Starting Issue #2
Damn... 2023? That's a surprise.
Once when my mower exhibited a similar behavior, it turned out to be the seat occupancy delay module/relay. Apparently, a relatively common failure on my 2007 ZTrak model... but that was 15 years old when it failed. I also had a seat switch housing break on my old Deere 855 CUT, which caused it to think I wasn't in the seat, but that was over 30 years old when it failed.
I've never owned a mower with a digital display, but I assume it would tell you if the brake switch didn't detect engagement, or the SCV levers weren't properly docked, or the PTO switch were still on, or it thought you were out of the seat?
There should be a simple flow chart under Troubleshooting section of your user manual, basically an idiot check list. You probably already thought of all those items (levers out, brake on, PTO off, butt in seat), but maybe worth checking. I found the bad seat delay module by following the more extensive checklists in the shop manual for my model, which I usually buy with each tractor or mower.
Ingersoll Rand 66" Padfoot Shell Kit (A42021)
Ingersoll Rand 66"...
2015 KENWORTH T800 CRANE TRUCK (A45333)
2015 KENWORTH T800...
18in Tooth Bucket Wain-Roy Brand Quick Attach (A44391)
18in Tooth Bucket...
2007 Ford F-250 Pickup Truck (A44572)
2007 Ford F-250...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
2008 TRAIL MASTER, INC. GOOSENECK TRAILER (A45046)
2008 TRAIL MASTER...
