Item Details
- Auction ID
- 55314
- Make
- Kubota
- Type
- Miscellaneous
- Year
- 2023
- Auction House
- Fastline Auction, LLC
- Model
- Z252KH-54
- Location
- North Carolina
Description: The Kubota Z252KW-54 doesnt just bring you precise cuts and efficiency as you work throughout the day; it amplifies your experience with its ease of operation and dedication to operator comfort. The K-RIDE comfort system with a standard suspension seat, and a 24 horsepower Kawasaki engine, youll never stress your zero turns performance. With three blades, Push to start, standard foldable ROPS, and a 4.3-gallon fuel tank, theres no denying that the Z252KW-54 is truly the ultimate, residential zero turn mower. Newly designed HST levers, thick rubber cushions under the step place, and a 21in High back suspension seat make up the Kubota K-RIDE comfort system, offering superior comfort (suspension seat standard for Z242KW-48 & Z252KW-54 models only; Plenty of legroom up front, thanks to a wide foot pan; Cup holders; Dual operation levers provide the smooth, precise control you'll need for delicate trimming and work around trees and flowerbeds; Covered storage boxes for your tools, lunch and anything else!; Fixed ROPS to ensure operator safety; This 10 gauge steel, welded mower deck provides outstanding, professional-level cutting performance. If you're a homeowner who wants the best, this mower deck is for you. Push to start allows for easy one-handed operation of the choke and engine start switch; Toolless step removal; Patented K-Lift pedal (mechanical one push deck lift pedal) makes adjusting the cutting height simple. 1/4in increment cutting height adjustment with the simple twist of a dial. Ergonomic control layout for quick, easy access. Year: 2023 Make: Kubota Model: Z252KH-54 Serial #: KBGHGEB0CPGB10131 Hours: 1.0 Stock #: E79727 FASTLINE SALES REPRESENTATIVE(s) Nick Herring nick.herring@fastline.com 919-922-2854 Item Location - Address: Provided by Seller Item Location - City: Fayetteville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 28306 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
2023 Kubota Z252KH-54 Zero Turn Mower
see lot description, multiple locations, KY 40010
Starting Bid: 2500.00 USD
Auction Finishes: November 04, 2025 at 06:20 PM
Click Here To Bid Now!
Happy Bidding!
Happy Bidding!
