2030 hydraulic leak
   / 2030 hydraulic leak #11
:eek: Just sent my J2030H back to deer-- still leaking.... they are embarrassed... I'm am beginning to get concerned. stay tuned. Phil
Thks fot the update even though its dissipointing. Good luck.
Jack
   / 2030 hydraulic leak #13
Spoke with service manager re: leak- He said it was a fitting that wasn't tightened properly- they are in process of running (testing) tractor to insure that they have resolved issue. I'm hoping they have- will know more in a day or so.
I'm curious if it turns out to be a loose fitting, where its location is and if its a supply line, a retutn line or a psi switch connection.Thks again. Jack
   / 2030 hydraulic leak #15
Well they picked up my tractor for the third time today- I expect that they will take a bit more time looking for the leak this time. Will post with findings when I hear. Happy New Year......I guess....
   / 2030 hydraulic leak #16
I would think they will get it right on the third try!!!! :pullinghair:
   / 2030 hydraulic leak #17
That's my expectation..... but not holding my breath since I expected it fixed on the first and second try too.....lol
   / 2030 hydraulic leak #18
Well finally got the leak sorted out- there were two leaks actually. first one was a hydro line that needed another half turn to seal. The second was coming from my loader valve quick disconnects- I had two of them that were leaking- both replaced under warranty and no more leaks- hope this helps another forum member avoid being frustrated to edge of looney bin..
What about the leak from the tranny case. Did they split that for nothing or was it leaking also.
Thanks Jack
   / 2030 hydraulic leak #20
Thanks Jack
Yeah they split the case to fix the third leak- they got that one the first time the tractor was in.
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
2015 Ford F-250 Auto Crane EHC32 3,200lb. 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
Deere 331G (A53317)
Deere 331G (A53317)
1111-A (A54756)
1111-A (A54756)
