Ray2210
I have a 2210 and at 470 hours ran into the drive shaft u joint problem. About two years ago at 400 hours I had the rear PTO grenade when I picked up a small piece of wood in the snow blower and the shear bolt was stronger than the transaxle. During the $10,000.00 repair that insurance coverered 7 grand of I specificlally instructed the dealer to make sure that the drive shaft was properly lubed. It didn't happen and there was not a spot of grease to indicate it was ever lubed. I pulled the shaft and replaced the u joints. I inspected the yolks and all appeared fine. When fully engaged the rear yolk is tight to the splines. What I didn't figure on is the overlap is 2/3 or less on the rear yolk when installed. Installed the rear yolk has about 9 thou of lateral play and feels much worse than 9 thou sounds. I discussed it with the dealer and they came up with a used shaft from a 2305 that had never had a u joint failure (new here that shaft is criminally priced at $730.00). I installed it and measured everything I could on mine and the used replacement. All the dimensions I could take with a caliper are identical and the slop in the splines is too. I'm having a hard time imagining that two tractors would wear exactly the same to the thousandth of an inch especially when one never had the shaft failure.
I'm wondering what the spec is for allowable play in the slip joint and if this is some kind of common problem or just horrifyingly in spec. I have found very little when searching with regards to a spline/yolk issue so little in fact it leads me to believe that if I bought a new shaft that I'd have the exact same slop.
Worse I can't imagine having to replace an input shaft on a two year old transaxle.
Does anybody here have any input to guide me here? I really don't want to spend 700 plus on a shaft just to find it the same as the two I already have.
I'm pretty unimpressed with John Deere from the problems I've had and am thinking lately that Orange is a nice color.
