2210/2305 Rear PTO broke.
   / 2210/2305 Rear PTO broke. #1
myersjc
2005 Bobcat Toolcat 5600
Heads up for 2210/2305 owners. If you run a brush hog or any other attachment that may shock load the PTO make sure the slip clutch is functioning or shear bolt is the correct softnness. I have a LX4 that found a rock hidden in the grass. it broke the bearing bore in the main housing of the transmission. I wound up having to replace the main transmission housing, rear cover and several gears. All said and done the bill was almost $2000 for parts and I did all the work.
John Deere recommends loosening the clutch on the LX4 and allowing it to slip several times after an extended storage period. I didn't do that this spring and I think that allowed it to freeze up since the rock completely stalled the engine as well as breaking the housing. Needless to say I will do it religiously from now on as well as running it looser.
The broken piece is here
2006_06_16
2006_08_09
2006_08_10
   / 2210/2305 Rear PTO broke. #2
WOW!
How many extra parts did you have left over?
   / 2210/2305 Rear PTO broke. #3
This is an amazing post. And just about the ultimate nightmare most of us could imagine. Thanks for the post and heads up! :)
   / 2210/2305 Rear PTO broke. #4
:eek: WOW if the motor stalled, then the clutch definately didn't slip much if at all!
   / 2210/2305 Rear PTO broke. #5
Wow.. that's frightening! What grade bolt were you using? Where did it come from?
   / 2210/2305 Rear PTO broke. #6
I think he mentioned slip clutch. Im the first to say I get confused on how they get adjusted. I will pay more attention to my tiller going forward....
No way it could have been warranty covered? yikes
Yes I have the slip clutch on both my LX4 and the tiller. From now on when I use either one after they have been sitting for more then a few days I will be loosening the clutch and slipping several revolutions first to be sure it is not froze. I have also been told to watch out for the length of the driveshaft on the LX4. I guess if you are not using the iMatch the driveshaft can be to long causing it to bottom out if brought all the way up
   / 2210/2305 Rear PTO broke. #8
Now I'm confused.... shouldn't there be a shear bolt on the shaft where it connects to the PTO (whether you have a shear bolt or slip clutch on the deck)? This is where the bolt is for my buhler rear mount blower.
G
   / 2210/2305 Rear PTO broke. #9
No shearbolts anywhere else in the system if you have a slip clutch. That's what the clutch is for, as it keeps you from constantly sheering bolts in tough conditions (and having to stop and replace them).
   / 2210/2305 Rear PTO broke. #10
Holy Cow, that is just unbelievable!!! There is no possible way I could repair that!. I have read in the manual for my MX6 about the procedure for keeping the slip clutch from sticking. I will DEFINATELY learn how to do it.
2023 Isuzu NPR S/A Dump Truck (A56858)
2023 Isuzu NPR S/A...
2014 Yamaha YRDEX4 Golf Cart (A56859)
2014 Yamaha YRDEX4...
Kubota L3830 (A57148)
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
JRB 107" Bucket (A57148)
JRB 107" Bucket...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
