2305 WONT CHARGE BATTERY BLOWS BULBS
   / 2305 WONT CHARGE BATTERY BLOWS BULBS #1
chazdo2
Bronze Member
auburn new york
walk behing power drive 21
Have a new and old rectifier/ regulator. All connections are good. Puts out 33 volts DC! Generator puts out 22volts AC. Continuity checked every wire great grounds. HELP!!!
   / 2305 WONT CHARGE BATTERY BLOWS BULBS #2
It sounds like your rectifier is to fault. More than likely one or more of the diodes are bad.
the internal regulator diodes or the other ones on the wiring diagram? How many AC volts should the alternator put out?
   / 2305 WONT CHARGE BATTERY BLOWS BULBS #4
The regulator regulates DC voltage once it is rectified from AC to DC. It looks like the 2305 has a 2 leg stator and a combo regulator/rectifier. This thread has wire diagram:
2305 light problems
This person had 49ACV coming out of the stator which sounds ok. Unrectified high voltage will cook anything that is turned on...like bulbs. Many people have problems with cheap replacement regulator/rectifiers too.
John Deere Compact Utility Tractors | 2305, battery not charging | Facebook
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
2013 Ford F-150 Pickup Truck, VIN # 1FTFW1ET0DKE69536 (A48837)
2013 Ford F-150...
Simpson 3400 PSI Pressure Washer (A48837)
Simpson 3400 PSI...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
Super Material Lift MH1000 (A50397)
Super Material...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
