2515 air filter assembly to 3515 dual element.
   / 2515 air filter assembly to 3515 dual element. #1
nosaj2
none yet
Has anyone ever tried changing the air filter assembly of a 2515 to the 3515 assembly?
   / 2515 air filter assembly to 3515 dual element. #2
I don't see why you should not be able to change this out, as long as the air outlet of the housing matches the air inlet for the tractor, and you can hose clamp them together, and you have the room under the hood in theory you should be able to replace it with any dual stage air filter setup and honestly i never understood why they went to a single stage for that model anyway in my opinion any tractor that size should run dual stage air filters, its just better protection for the engine is my thought on it.
   / 2515 air filter assembly to 3515 dual element. #3
Aren't both filter housings the same? Should be a matter of getting the inside filter and put it on? It's a Donaldson air filter setup.
Mine came with just the outer filter as well. My dealer mechanic advised me to get a inner one. Pretty much 500 hours later, the inner one is still brand new.
2014 Doosan DA30 (A50397)
2014 Doosan DA30...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2006 International 9400i (A50397)
2006 International...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2022 Club Car...
2022 CHEVROLET LCF 4500HD 16FT BOX TRUCK (A50505)
2022 CHEVROLET LCF...
