2538 HST pedals won't return to neutral - Help!
   / 2538 HST pedals won't return to neutral - Help! #1
slharman1
Bronze Member
Waller, Tx
Mahindra 2538 HST
Got on my tractor one day and push down on the forward pedal and it stayed there. I can still use the tractor but now I have to "feel" for neutral.
I can't seem to find any information out there on what to do.
I have a Mahindra Service Catalog, but it is not very well written ( I think it was written in India) Does anyone know how to get more information on my problem or where to get better service manuals?
Need some help with this!
Steve
   / 2538 HST pedals won't return to neutral - Help! #2
Start by examining the linkage and lubricating it. On all my Kubotas, it's supposed to be lubed every so many hours and I can understand why. I suspect that if you are asking like this, you haven't looked at it or lubed it before.
Beyond basic maintenance, there is probably a damper in the mechanism that might need replacing. It's only there to control the rate of return to center, but if it fails or sticks, it can stop the pedals from centering up.
   / 2538 HST pedals won't return to neutral - Help! #3
A lot of the Mahindras have an external spring with the linkage. It may have come off. The linkage etc is just under the floorboard from the pedal.
   / 2538 HST pedals won't return to neutral - Help! #4
There is also a grease fitting on the peddle linkage/arm under the floor board. If you haven't greased it, do that also.
   / 2538 HST pedals won't return to neutral - Help! #5
This just happened to me on my 2638 while plowing, spring broke on one side and popped off. Hoping my dealer has one in stock.
2011 Ford E-350 ETI 29 SNV Bucket Van (A42742)
2011 Ford E-350...
2009 PETERBILT 367 TWIN PUMP CEMENT TRUCK (A45333)
2009 PETERBILT 367...
7' WORK BENCH, 18 DRAWERS (UNUSED) (A40519)
7' WORK BENCH, 18...
2022 Bobcat E60 Excavator (A42203)
2022 Bobcat E60...
100ft of Steel Fence (A39235)
100ft of Steel...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A43003)
2020 INTERNATIONAL...
