2610 HST & hydraulic filters.
   / 2610 HST & hydraulic filters. #1
Lee Robinson
Bronze Member
Brandon, MS
Kioti CK2610 HST
I don't want to post the same topic twice, but thought some Kioti tech may be observing this section of TBN but not the hydraulic forum section...so here is a link to the original post.
   / 2610 HST & hydraulic filters. #2
Comes from the same tank, using the same oil but 2 different systems. I often thought the same, but the only reason I could think of was that the HST oil has to be as free of debris as it can be while going into the transmission.
   / 2610 HST & hydraulic filters. #4
Typically Even larger hydrostatic drives have a dedicated charge pump
Filter as well as other filters on the system. Filter element $30 new hydrostatic $3000 so filter is very inexpensive insurance
   / 2610 HST & hydraulic filters. #6
I have the same Tractor. Seems the manual is a bit unsure of service intervals for hydro filters and fluid after 400 hours? I did hydro filters and fluid at 50 hours and again at just shy of 300 hours. In the future I would like to do fluid and filters at the same time? What would you guys' recommend hour wise?
Thanks for the info guys. I am very pleased with the capabilities of the CK2610 HST.
   / 2610 HST & hydraulic filters. #8
While the tractor only has "one hydraulic fluid reservoir", it has a "2 step filtration" if you will. The HST filter is of a finer micron and rated for higher pressure and therefore more expensive than the regular hydraulic filter. Because of the nature of the tight tolerances on the HST transmissions, etc it is very important to use the correct filters and if you consider using anything other than OEM, make sure you do very good research and make sure you're using filters that are rated correctly for your tractor, or you could see expensive HST repairs.
2015 Ford Focus Sedan (A46684)
2015 Ford Focus...
2019 Ford Explorer AWD SUV (A46684)
2019 Ford Explorer...
2021 Ford F-150 XL (A47307)
2021 Ford F-150 XL...
1990 20' Custom Trailer 20T202AS (A43476)
1990 20' Custom...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A46683)
2016 New Holland...
Above Ground Tank for Flammable Liquids (A43476)
Above Ground Tank...
