dullpain
Platinum Member
- Joined
- Aug 2, 2000
- Messages
- 509
- Location
- Middle Tennessee
- Tractor
- Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Took delivery of a B2910 5 weeks ago. Tooled around the place slow and easy till I got 12 hours on her. Never used the mower. Under 1700 RPM. 2 weeks ago mowed the lawn first time. About half way thru (1.5 hrs) Engine just choked down and quit. Gave it a few minutes after looking about and it started right up and finished the rest of mowing without incident. Last weekend went to mow still taking it fairly easy at about 2000 RPM. Choked down again, & again, & again. I'm puzzeld?? Acted just like it ran out of fuel and it was. Fuel filter very dirty but not clogged. I was amazed about this on a new tractor. Changed fuel filter, Drained Fuel Tank and inspected Tank. Found several insect wings intact, Grit ,Grime, Paint chips, 1 large well preserved dead spider, 3 each curly cue plastic shavings like when you drill a hole in plastic. One of the plastic drill shavings had worked it's way into the fuel line at the tank exit. Got it all out and seems to be fine now. Still kinda amazed that it happened. Think that is all that was wrong. At 17 hrs now and going to mow today. Will let you know if not OK.
Wednesday Apr 24 - All OK now - anybody else have this trouble??
