3000 position or draft contro lever
   / 3000 position or draft contro lever #1
cotemart
Hi there, we just bought a 1971 ford 3000. Everything is working well on the tractor exept the position control. After reading on the forums (What a great resource), I suspected the hydraulics to be stuck in draft control mode. The lift acts the same way even if we place the position control selector up or down. I mean the lift start raising only when the control lever is close to the top (which I understand to be a normal behavior in draft control). So I tried prying the draft control spring with the top-link and the control lever just under the point where the lift start raising. It makes the lift raise with no problem and smoothly. So I think the valve and cylinder are in good shape.
So is it a common problem to have the selector stucked in draft or position control. If so, is it hard to fixe?
Thanks, I just hope I made myself clear :eek:)
   / 3000 position or draft contro lever #2
No.. it is not 'normal' to be stuck in draft mode.
get a master parts catalog, or other parts manual to show you the top cover and unloading valve. You may have stuck or bent linkages and / or bad springs. cam pin.. etc. Get a repair manual as well if you intend to do the work yourself. The I&T FO manual is ok.. and may work for this repair.. however the larger ford manual will be better.
Soundguy
2010 MINI Cooper Hatchback (A56859)
2010 MINI Cooper...
24in pin on excavator tooth bucket (A56436)
24in pin on...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Freightliner Tender Truck - Adams Tender (A56436)
Freightliner...
EquipmentDealz (Preview Dates and Times) (A59213)
EquipmentDealz...
