30k tractor budget
   / 30k tractor budget #21
Labor costs strongly influence tractor prices.
Parts support networks also influence tractor and equipment prices. The South Korean tractor brands don't have the same parts infrastructure in place that Deere and Kubota have.
   / 30k tractor budget #23
And thats what confuses me when im searching, the big frame compacts overlapping with smaller utility tractors, i mean i would say it would be better to have a utility tractor, it just doesnt make sense to pay so much more for a compact style tractor of the same power. And every make seems like they have multiple series of tractors in the same hp range so its trying to find out which one is right and should i be paying more for the same hp for some reason.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations. In your case a bare tractor weight of 3,700 pounds to 5,000 pounds seems appropriate. I would consider a 50-horsepower/4-WD tractor, which will weigh about 3,700 pounds bare tractor weight, suitable for working ten to twenty acres. A tractor with a bare weight of 5,000 pounds is suitable for actually working 20 to 40 acres of farm acreage. Working acres, not total acres.
Bare tractor weight is a fundamental tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
Tractor weight largely defines tractor capability in pulling applications.
Heavier tractors are built with thicker steel and thicker axles to withstand the stress of heavier applied loads.
Heavier tractors have larger diameter, greater breadth wheels/tires, creating a larger tire "patch" in contact with the soil. Rear tires are often ballasted internally with liquid, placing weight directly over the tire tread. Larger wheels and tires and a longer wheelbase permit heavier tractors to bridge holes, burrows, ruts and tree debris, increasing ground speed and reducing operator perturbation. Larger wheels and tires increase ground clearance, lengthening the period which row crops may be implement cultivated.
Heavier tractors have FEL lift and Three Point Hitch lift in proportion to weight.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second, rear axle width/rear tire spread third, rear wheel ballast fourth. Ample tractor horsepower is needed for PTO-powered implements such as Bush Hogs and snow blowers, but remains subsidiary to tractor weight in defining tractor capability.
   / 30k tractor budget #24
Round bales and goats work if you use a sheep/goat round bale feeder. They have a lot of small bars to keep them off of it. If you feed goats round bales with a cattle or horse round bale feeder the goats will waste about 50% or more of the bale from climbing on it and bedding in it.
Yeah ive seen quite a few different designs that work well for goats. I saw i really like that was homemade, it expanded to load a round bale and had a trough to catch hay that falls off and as the bale is eaten it collapses in on the bale. But thats something im going to be looking more into.
   / 30k tractor budget #26
What is semi-mounted?
The cutter uses the lower two arms of the three point but not the top link. It uses a set of tail wheels attached to a hydraulic cylinder to lift the cutter. This results in a cutter that doesn't put all of the weight on the 3 point but isn't as long as a drawn cutter attached to the drawbar.
   / 30k tractor budget #27
Yes it is confusing. It took me two years of study and research to unravel the ball of yarn all this is when you first get into it. What's so different about the way tractors are sold from every other type of equipment out there is depending on the options, you can purchase a bigger tractor with more horsepower for less then you can a smaller tractor with less horsepower. So let's unpack this a little bit.
Lets' take the MX5400 for example. They offer a two wheel drive version of that tractor that is around 22K MSRP without a front end loader. However, you can not get an HST, it's only offered with an 8 speed partially synchronized gear drive transmission so they're selling weight and power without efficiency. If you want the HST they make you take MFWD and charge $7K more for it. So they're selling efficiency at a premium because they gave you all the weight and power as standard features.
Now let's take a John Deere 3R series as another example. That is Deere's premium medium size compact tractor line so they offer all those tractors with best in class transmissions, ergonomics, weight and efficiency. So they're selling power at a premium because they gave you all the efficiency, weight and comfort as standard features.
Each manufacturer offers a different set of standard features and premium features within each class of tractor that they sell. It will make it easier to wrap your brain around it if you can make a distinction between what is standard and premium.
   / 30k tractor budget #28
I believe after looking ill be really leaning towards the MF 2606h or 2607h, i cant believe they are at the price points for the amount of tractor you're buying. At about 32-34k i think they may be close enough cash could talk. If not i could be there after another week or 2. Now if tax returns dont come out like im calculating i may still be looking at used but come about February ill be getting something or ordering one way or another.
The Workmaster and deere 5000 series are both comparable to the MF2600 line. They are a true small utility.
The Boomer is more akin to the kubota MX line and the deere 4000 series which are the larger compacts. They are lighter, have smaller front wheels, Usually a HST option.
Foy haying and handling round bales regularly....I think you are on the right track looking at the utilities.
   / 30k tractor budget #29
Interesting. Any chance you would have some pictures of this?
   / 30k tractor budget #30
Theres actually a lot of goat farmers using round bales, for the same reasons im sure, not having to keep up with throwing square bales out so much. Now what size they do im not sure, they may use any of them. I wouldnt really need to use over a 4x4 or 4x5 right off the bat until i get more land and the herd grows but i want to be able to safely maneuver any size id like.
Now i dont have enough land to benefit from doing my own hay right now but i also dont want to have to go buy another tractor once we do get more land and if i decide to. Between that, bush hogging, the heavy work to be done with clearing out woods on our hilly terrain, gravel, etc. Thats mostly where my 50hp minimum comes from. If i was staying at 14 acres, feeding square bales, and knocking down the grass id of stuck with a mid 30hp just to run a bigger mower.
As mentioned if you are bailing hay rounds, the MX isn’t enough tractor. The M7060 is ok for smaller rounds, but no one actually bales those in TX. You need 100HP or so for a full baler. You arent going to be bailing large rounds with a 50HP small ag utility tractor.
The MX series transporting large round bales will be sketchy across a pasture, but can be done. It isn’t something I would do multiple times a day.
You mention 50HP for logging, but you do realize HP has nothing to do with what a tractor will lift and carry. You need to look at tractor weight, FEL lift capacities, and rear ballast. The first 2 are based on they specific machine, the last you can play with.
You are correct that you should go utility tractor, no reason not to…they are made for the lots of work you intend to do.
2020 International MV607 16ft Morgan Dump Truck (A55852)
2020 International...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A56138)
2019 PETERBILT 579...
Kubota M108S (A53317)
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
