3320 Forward and Reverse Intermittently Stopping at Higher RPMs
   / 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #1
pmqdflls
John Deere 3320
I have a 2011 JD 3320 eHydro with just over 500 hours on it. I've been using it regularly of late to move mulch, bush hog fields, tow a trailer around the yard, etc and no issues. When I went to do some tilling today the forward motion stopped suddenly – forward and reverse pedals did nothing. No strange noises, no drop or spike in RPMs, just no response to either pedal. After confirming I hadn't accidentally bumped into neutral, I shut the tractor off and checked the wiring under the pedals which seemed normal. Once I restarted things seemed to be working again so I assumed there was a loose connection or some debris, until a few minutes later when the same thing happened. What I eventually noticed is that if I throttle down all the way, they begin working again like normal. But as soon as the RPMs get up above 1500 or so, the issue repeats within a few minutes. I checked the oil level and that seems fine and the wires seem okay as well. No error codes have flashed, so I'm somewhat at a loss as to where to begin. Thanks for any advice!
   / 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #2
Welcome to TBN
Hope others see your situation and can chime in to get you some help, or ideas to check something out.
   / 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #3
Questions:
Does the same issue happen in A, B, and C speed ranges, or just in a certain range?
Does the issue happen with Mechanical front wheel drive (MFWD) on or off?
Does the PTO work correctly at low and higher (above 1500) RPM?
2011 Chevrolet Silverado LT Ext. Cab Pickup Truck (A42744)
2011 Chevrolet...
Fence (A39235)
Fence (A39235)
Vermeer BC1800A Chipper (A44391)
Vermeer BC1800A...
2008 Polaris Ranger XP Sportsman 800 4x4 Utility Cart (A42744)
2008 Polaris...
2016 Ford F-150 Crew Cab Pickup Truck (A44572)
2016 Ford F-150...
10' Storage Container (A45788)
10' Storage...
