3320 rolled and damaged...new purchase
/ 3320 rolled and damaged...new purchase #1
hanson1999
minnesota
JD
i just bought a 3320 and 300cx loader....2008 models, rolled over and broke hood, bent rops, and ripped one 3 point arm out of tranny and axle case. also ripped top link out. i know i can fix the top link part easy, but the tranny case gets expensive. i'll send some pics once i get it home i bought it online over a salvage auction, thinkin i'll get it goin reasonably...pics to follow any ideas appreciated....174 hrs on tractor...r4 tires....gonna be good i hope!!! 2009 2520 will be for sale...117 hours on that one!!
/ 3320 rolled and damaged...new purchase #2
Anxious to see the pics. Sounds like a project.
/ 3320 rolled and damaged...new purchase #3
Sounds like a very interesting project, I am very curious what you paid for it though?
/ 3320 rolled and damaged...new purchase #4
Just curious but do you know if the operator who rolled it got hurt? Or worse???
kebo....not sure at all but i'm guessing it couldn't have been good, the seat brackets are bent and steering column needs some work also.
here are some pics, i have since tore the tractor down, more pics to follow.
right now my biggest problem is none of the 3 point arms came with the tractor. deere wants unbelievable money for those parts. i am going to go with aftermarket parts have been looking on the net alot.
Does anyone know a good place for 3 point arms and parts??
Also anyone know of any salvage outfits where i would maybe find used parts for this compact utility??
That rockshaft housing is around $700 new, would love to save some money on that!!
The loader is in great shape, 300cx with 61" HD bucket.
/ 3320 rolled and damaged...new purchase #8
The arms are cheaper if you buy the Telescopic Kit thru Whole goods...I want to say just one of the normal arms is $250ish but the kit of both telescopic arms is the same price if not less...
The rest of the 3pt linkage could be fabricated fairly easy...If I were in your shoes I'd build one of the lift links and get a TNT link for the other side from CCM.
/ 3320 rolled and damaged...new purchase #9
Worthington Tractor Salvage, Worthington MN. (and other locations in the midwest) is pretty big in this area.....I'd check 'em out.
/ 3320 rolled and damaged...new purchase #10
I had a similar problem with a rockshaft housing on a Massey I owned. I took a grinder and ground the damaged area as flat as I could. I made a box out of stainless steel and left ears all around the outside. I drilled holes in the ears and matching holes in the casting.
Then tapped the casting holes, put a thick layer of silicone sealer on and bolted the stainless box onto the casting.
It worked like a charm, just make sure to make the box deep enough to allow the piston for the rockshaft to extend to it's full travel.
/ 3320 rolled and damaged...new purchase #11
That rockshaft housing is around $700 new....
Looks like a fun project, HANSON!
I think you will find the axle housing is a similar amount. Also, I can't see
what kind of hood damage you have, but that green plastic can be more
than those castings.
3x20s are still very new....it will not be easy finding any salvage units.
i lucked out and found all the three point parts.....a mile from home even.....hope to get this guy runnin soon the three point rockshaft housing is the big wait now....i can't wait to get this tractor functioning!!
/ 3320 rolled and damaged...new purchase #13
I would also like to know what a tractor in this condition went for at
auction. I like to buy them that way. Maybe I should consider going to
auctions again......
update...
Just got rockshaft housing replaced and put back together. everything seems to work good. No fenders or seat back on yet.
I noticed it was throwing a couple codes on the display panel
65 and 67
My service manual doesn't list either of these, anyone have any ideas??
/ 3320 rolled and damaged...new purchase #15
Codes 65 and 67? I think 65 is "sell tractor to Gizmo2":D
/ 3320 rolled and damaged...new purchase #16
65 and 67
So, I guess you have an eHydro tranny then. Error codes not in the
service manual? That's a surprise....I figured the factory manuals would
cover that. I hope that JD can help.
I guess we are not going to hear about the economics of this rebuild....
/ 3320 rolled and damaged...new purchase #17
update...
65 and 67
From the Technical Manual
Err 65
Right Amber Light OFF
Output from the Display is open
No right hazard signal on the ROPS
Check the right hazard light bulb, Check the 135 Grn wire for short to battery voltage or open circuit.
Err 67
Left Amber Light OFF
No Left hazard signal on the ROPS
Check the Left hazard light bulb, Check the 145 Grn wire for short to battery voltage or open circuit.
/ 3320 rolled and damaged...new purchase #18
When it is completely done the price will be 80 to 90 percent of current market value. I have never seen any real deals. There is always someone raising their hand at unbelieveable prices for these " projects ". Now for eternity there will be bearing failure and seal leaks raising to the surface. Too many aluminum and cast parts on these machines that will cause problems. I will pass and buy new.
When it is completely done the price will be 80 to 90 percent of current market value. .
how would you have any idea what i have into this???? Do you have a source for parts at cost??? I DO!!!!! Do you have a source for miscellaneous used parts??? I DO!!!
That is all besides the fact you have no idea what i paid for it to begin with.....
So I have a leak or bearing to fix down the road, at least i will have half of market value into mine and when you paid full price for one who got the better deal?????
Who wouldn't wanna have 10k into a 2008 3320 with 174 hrs??? i bet i get alot more than that when i trade it in!!!!!!!!
Thanks mattz for the codes, makes sense i have the rops off the machine now..... my tech manual on cd skipped right over those two code numbers....
/ 3320 rolled and damaged...new purchase #20
To the fox who can not reach the highest grapes they are surely the most sour.
Good luck with the restore Hanson. It's something I'd do myself!
