3320 throttle ….is it working ?
   / 3320 throttle ….is it working ? #1
mx125
Toronto
JD 2320
Hello. I have an ailing 2320 and had a look at a used, high hours, but seemingly very well maintained 3320. My quick test in his driveway was fine, but throttle very different and wonder if it’s normal.
My 2320 has a very direct throttle. A few mm of movement and Precisely equivalent change in rpm. I can tap tap with palm and get small fixed change.
On 3320, I would move the smaller throttle a certain amount. The 3320 would rev up and then settle to a fixed new higher rpm. Not a fixed direct relationship. Very indirect and revvy (not a word).
Is this normal? Perhaps it has a bit more of a brain than my 2320 and aurorevs and settles down.
just worry it’s something I’d need to send in and not keen on that. Wonder if any owners have insight.
Thanks.
   / 3320 throttle ….is it working ? #2
From the explanation and if I understand, sounds like a linkage hanging up. Some good penetrating oil might do wonders. I use Blue Creeper as I've found it better than Kroil and much better than WD-40.
Ok. So you think it should have the same rock solid direct connection to rpm like my 2320? I read about load match but not sure what it is not it this tractor has it.
   / 3320 throttle ….is it working ? #4
That does not sound normal, cab or open station?
Open. It’s a 2006. So the rampy revs is normal ?
   / 3320 throttle ….is it working ? #6
My 15+ year old MF1540 throttle was acting the same; in that it would not idle all of the way down. I could idle it down with my finger in the engine compartment, so it was basically sticking. Sprayed it with electrical cleaner and then lubed it; works fine now.
Ok. Thanks all. Seems like not a big issue in any case so will take another look.
   / 3320 throttle ….is it working ? #9
Is this normal?
I have an open station 2005 model year 3520 with around 1000 hours on it and this sounds similar to the way my throttle works. The engine RPMs will reduce slightly after moving the throttle up to increase engine speed. The RPMs will then remain steady after they have reduced a bit. It has always worked this way, so I consider it to be normal operation as I don't have anything to compare.
What model year and how many hours on the 3320?
Thanks. It’s a 2006 with 3500 hours. I know it is a LOT but I know the use history and very light. Condition seems exceptional. I have had my 2320 since 2006 and 850 hours. So even if I used for 10 years ….I would prob be at 4000 on the 3320. I get mixed feedback on the value.
2011 Ford E-350 ETI 29 SNV Bucket Van (A42742)
2011 Ford E-350...
2016 Ford Explorer AWD SUV (A42744)
2016 Ford Explorer...
2019 Ford F-150 XL (A44501)
2019 Ford F-150 XL...
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2016 Chevrolet Tahoe SUV (A42744)
2016 Chevrolet...
PETERBILT FUEL TANK (A45046)
PETERBILT FUEL...
