3Pt hydraulics question
   / 3Pt hydraulics question
Will do as soon as i find the tractor, apparently my dad stole it to do some work at his house. I'll have to run out and look tommorow.
Well I took a closer look at the "add on" valve. I scraped a few numbers off of it but really couldnt find anything on the valve other than its made by "Energy" hydraulics. They do have a website but i still do not see the model numbers crossing over anywhere. Story it short the valve looks to be installed correctly. The "out" at the rear of the tractor runs into the "inlet" side of the valve. The "outlet" of the valve then returns back to the rear of the tractor labeled "return". Then of course the output lines simply run off the side of the valve body. I think the wrong valve is being used and may just need the correct one from what im seeing, its plumbed correctly and getting a picture will be almost impossible as its mounted inside the fender and i dont think that will do any good honestly. There are a few numbers on the valve. 1008U was the number i figured was the model # but nothing came up in any searches anywhere. Maybe i'll email energy and see what i can scrounge up. I'll update when i figure it out, probably needs the power beyond valve, it makes sense and sparks something from tech school hydraulic class.
Well here is some new info. It seems as though the add on valve for my tractor "grapple" or "thumb" is commonly used for a log splitter set up..
Here is the valve specs:
Log Splitter Valve and Accessories by Energy Manufacturing Company, Inc.
What type of valve would i need to over come this. The add on valve only moves to the hydraulic kickout side when i want to raise my 3pt hitch, it does not move the other way. Would a simple standard valve work (no hydraulic kickout needed)
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2012 Ford F550 (A52377)
2012 Ford F550...
2017 BMW X5 SUV (A53117)
2017 BMW X5 SUV...
2016 Ford F550 (A53422)
2016 Ford F550...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
