ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 28,645
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
I spin the Rotary Phase Converter for by Bridgeport with my hand and need to use a rope pull for the 5hp Converter for the Air Compressor.
NOT to complicate things... When I opened a new surgery wing where I work... there was a Breaker Tripping problem when power was switched between PGE Utility and the Hospital Standby Generator.
The explanation was the 10 hp HVAC ventilation motor was feeding back current and causing the trip. It was remedy be adding a delay module to the ONAN Generator Control so that transfer was not instantaneous... but instead about 2 1/2 seconds.
Generators operate 3 phase equipment all the time... I think you may be onto something to limit running your biggest load to Generator Power.
