4145 won稚 turn over
   / 4145 won稚 turn over #1
dstriplett
Bronze Member
NC
LS XR4145
My wife noticed that she had to jiggle the shuttle shift lever a few times to get it to turn over. Now that doesn稚 work either. I didn稚 have a volt meter with me to check wire harnesses, but I did check all of the fuses and the connectors and the battery terminal and ground wires and found nothing.
I知 assuming either the shuttle shifter sensor is bad or perhaps the starter solenoid or special fuse is bad. Any ideas? If it痴 the shifter sensor is that internal to the transmission?
Just under 200 hours on the tractor.
   / 4145 won稚 turn over #2
I'm unfamiliar with the tractor but suspect it's an adjustment thing either with the switch or the shuttle shift itself. It would surprise me greatly if the switch was inside the transmission.
   / 4145 won稚 turn over #3
Pull the plastic lower dash Cover off on the left side and you will see a little black magnet switch with a wire coming out the back, good chance that it is bad .
Thanks all. It appears to be the safety cutout switch on the brake pedal.
Mitsubishi FG35 Forklift  8,000lb Lift Capacity, LP Gas (A44789)
Mitsubishi FG35...
2008 Fisher 180 Pontoon Boat and Trailer (A44391)
2008 Fisher 180...
2020 GARDENER DENVER 2500HP QUINTUPLEX FRAC PUMP (A45333)
2020 GARDENER...
2015 FREIGHTLINER CASCADIA  CA125SLP TANDEM AXLE SLEEPER (A43003)
2015 FREIGHTLINER...
Club Car Electric Golf Cart (A44502)
Club Car Electric...
2009 INTERNATIONAL PAYSTAR 5900I (A45333)
2009 INTERNATIONAL...
