4600 Transmission/Rear Bolted to 2600 Motor
   / 4600 Transmission/Rear Bolted to 2600 Motor #1
jacain
Richmond (Chesterfield), VA
Ford 2600 Ford 3910
Have oporatunaty to pick up 4 speed and rear from a 4600. My 2600 currently has the 3 speed, so no live/independent PTO or diff lock. Just wondering if this would bolt up without any additional equipment? Thanks in advance for any help.
Justin
   / 4600 Transmission/Rear Bolted to 2600 Motor #2
You need the flywheel and clutch for the 8x2 transmission and it looks like you will have to drill and tap the bolt holes in the 8x2 trans housing for your radius rod sockets. And hope the hydraulic components in the rear axle center section are functional.
Thanks Rick. I should be able to score a flywheel if I'm patient. Probably just go with a new aftermarket clutch. I've got one of these to help with the radius arm modification. :)
Looks like it might already be drilled and tapped for the radius arms.
