4x20 cabin air filter
   / 4x20 cabin air filter #11
One day. AC full bore all the time
The sign you need to clean it is she you slam the cab door and dirt flies out of the filter.
D.
   / 4x20 cabin air filter #12
Look at the stuff piled up on the mower. Only AC filter is there at the top. Not a great location.
D.
   / 4x20 cabin air filter #13
I just went out and checked mine after 2 weeks and mine was dirty and the foam on the filter is tearing like yours.....:mad:......
   / 4x20 cabin air filter #14
There ya go. The blower is strong enough to tear the filter apart.
You have to keep an eye on it or it will plug up the coils and you have to pull the roof off to clean them.
D.
   / 4x20 cabin air filter #15
Im looking to see if Fram would have anything close to the same measurements I just took from the JD filter.....
   / 4x20 cabin air filter #16
I got nothing......:(
   / 4x20 cabin air filter #17
Brush hogging is a nightmare with these filters. I have to clean mine everyday. Very bad design..
   / 4x20 cabin air filter #18
My dad has same issue on his 4720. He keeps One on hand and just blows them out until they start to come apart.
The coils have gotten dirty and I found a good way to clean it without removing anything. It's a no rinse coil cleaner. Just spray in there and let it foam. Then either blow it out or you can rinse it too. The can says spray it on and forget about it. I had to rinse it, couldn't take it.
   / 4x20 cabin air filter #20
Coil cleaners work well enough, just make sure you are using one for evaporator coils. My coil got dirty when I used my tractor on the last job tilling a dusty field. I will be cleaning mine in a few days when I catch some jobs up. Lucky for me I am in the HVAC business so will post some pics for you guys if that would help.
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
2012 International 4300 Reefer Truck (A56438)
2012 International...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
