5055E and lifting a pallet
   / 5055E and lifting a pallet #1
Laminarman
Upstate NY
TC40DA
I'm deciding between a New Holland Workmaster and the Deere 5055E. The Deere seems more robust (as does the price.) A MAJOR consideration and maybe a game changer, would be if I could somehow lift a pallet with the Deere. I often have pallets of lime delivered for my food plots, and these weigh 3,150 pounds each. Lime trucks will not deliver to my fields. So I have to take the tractor around the barn and up a grade through the woods. What I do now is put the bags, by hand, on a hay wagon and haul that up, then bring up the lime drop spreader. If there was a way I could lift a pallet of lime either with the 3 pt hitch or front bucket, that would be a huge game changer. I can't find 3 point forks robust enough to lift that weight. I'm not sure if this tractor could lift it from the front, as I'm not aware how lift capacity "at the pivot pins" translates to lifting a pallet. Any experience anyone? The dealer couldn't answer the question either and he's checking with others to see if he can find the answer. Thanks in advance.
   / 5055E and lifting a pallet #2
The JD has an unfair advantage in that matchup. It's a LOT more tractor than the WM. It appears to you to be more "robust" because it is. The weight difference is almost 1500lbs.
I'm not sure that either of those tractors would be capable of carrying pallets that heavy.
Just curious, but your local fertilizer supply doesn't offer lime, by the ton, in a spreader buggy? That's common down here.
I never checked that because I knew my tractor wasn't big enough. I have a 40HP hydrostatic drive NH and I didn't think there was a chance that could pull one of those. That would be the ideal solution if it would work. Thanks. And the weight difference without a bucket is 1,000 pounds, not 1,500, but still very substantial.
   / 5055E and lifting a pallet #4
I think 3150#s of lime will be touch & go.
   / 5055E and lifting a pallet #5
I would assume you would also have to deduct the weight of the pallet fork attachment which is in the hundreds of pounds.
I wish I could post what I have from the dealer. He has a spec sheet that he got on his dealer website, and the heading titled "John Deere 553 NSL on 5E Series Tractor" and down that column at the "Lift Capacity at Pivot" is 4,008 pounds. Now, I'm not sure if that's the max and specified for the 65HP model but he told me he thought the 5055 could do over 3,000 with a heavy duty pallet fork. I should just buy a skid steer and call it a day :)
   / 5055E and lifting a pallet #7
When I bought my M8540 it was the most cost effective solution to be able to lift much over 3000 lbs to 60" at 800 mm. Most of the tractors needed to be in the 80 hp range. Some exceptions I looked at were the NH T4000 and the JD 5M I also wanted a power shuttle. The M8540 lifts close to 4000 lbs to 60"
The LA1153A 2646 lbs on the m7040
LA1353A 4144lbs m8540
Most of the 70 hp or less were under 3000 similar to the la1153
   / 5055E and lifting a pallet #8
lifting 4000#s at the bucket attaching pins is one thing and lifting 4000#s sticking out 4 ft in front of the pins is totally different
   / 5055E and lifting a pallet #9
Sure, but it will lift 2,900lbs to 1.5m at 800mm, so it would lift a lot more to a lower height. If he only had to lift it a foot or so, it might be as high as 4K.
   / 5055E and lifting a pallet #10
I don't know if it could lift a full pallet or not but I wouldn't bet against it. You would need loaded tires and a good weight on the 3PH. You could always move a third of a pallet onto an empty and go with 2000 which it should do with ease. The WM being much lighter wouldn't stand a chance doing it safely. I don't think there is a difference in capacity of a 533 loader if it is switched from a 5045 to a 5055 or 5065 tractor. The pump is the same size as are all the pistons. The only advantage is that a 5065 comes with larger tires that can hold more liquid ballast.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
OMEGA 20 TON CRANE (A58216)
OMEGA 20 TON CRANE...
2008 JLG  800S MANLIFT (A58216)
2008 JLG 800S...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
Highline Manufacturer BP661-100 (A57148)
Highline...
