58 ferguson wiring
   / 58 ferguson wiring #1
yrag
On the back of the key switch there is three prongs, I know what wires go there I just don't know what wire goes to what prong. need a helping hand.
   / 58 ferguson wiring #2
As a guess, the wires probably follow the direction of the key rotation. If so, the first wire should be 12 volts from the battery, the next wire should be the 12 volt feed to the ignition coil, and the third wire should go to the starter solenoid. This assumes you have a gasoline engine, and no starter button, and position 3 of the key is momentary ( spring loaded.) I have a '55 Ferguson, but I've rewired it with aftermarket parts, and I do have a starter button. As such, I only need two positions for my key switch ; off, and on.
78'' skeleton /rock bucket (A53421)
78'' skeleton...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
2005 Ford E-350 Cargo Van (A51692)
2005 Ford E-350...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
ALLISON TRANSMISSION (A53843)
ALLISON...
