65 MF135 generator to tachometer
   / 65 MF135 generator to tachometer #11
Most 3-152 and 4-203 used camshaft adapter for tach drive. All Continental used gen or alt gearbox tach drive, Perkins 4-212, 4-236 and 4-248 did too.
Interesting. I knew that later models were equipped with alternators, but I didn't know that the alternators were equipped with tach drives. Perhaps converting my 1966 Massey 135 from a generator to an alternator will be much easier than I had originally anticipated.
   / 65 MF135 generator to tachometer #12
i know a 10dn gm alt can have a tach drive fitted ( if you get the model setup as such.. )
Interesting. I knew that later models were equipped with alternators, but I didn't know that the alternators were equipped with with tach drives. Perhaps converting my 1966 Massey 135 from a generator to an alternator will be much easier than I had originally anticipated.
The only reason I found it and believe me I have been combing eBay like a stalker. I changed my search wording and brought up about 300+ more pages. I used "Massey ferguson" instead of adding 135 plus those two words. There is a tach drive only for sale for equipped GM alts for around $67.
I may even go as far as adding a fuse box when my new wiring harness comes in made for an Alternator. Robert
   / 65 MF135 generator to tachometer #14
Can anyone give me some advice on how to remove the Drive connector pictured in the post earlier by The kid. I have an MF65 AD4-203 and attempting to replace the tractor meter and the cable. It does have a camshaft adaptor on the upper rear of the cylinger block as pictured. The original cable seemed to shear off at the drive end, leaving the square key and a few threads of the cable, stuck in the drive connector, I believe. I can easily remove the housing but the stuck key won't budge and I can't seem to remove the drive connector. It may be seized. It is a difficult location to work on. Any tricks or suggestions??
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2018 Claas Volto 900 (A56469)
2018 Claas Volto...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2018 Caterpillar 259D (A53317)
2018 Caterpillar...
