790 starter will not disengage
   / 790 starter will not disengage #1
Hiltz
Michigan
JD 790
Hey guys, yesterday when I started my 790 I heard a whinning noise after the tractor started. I noticed when I push the clutch in it stopped. Also when I put the tractor in any gear the whinning stops. Only when the tractor is in neutral and running does it happen. Sounds like the starter will not disengage. Any of you guys had this problem and what did you do to fix it. Thanks tons, John
   / 790 starter will not disengage #2
Peter 315
Elite Member
NH
Kubota L3800 HST Kubota L47 TLB
Sounds like the clutch throw out bearing not the starter.....:2cents:
OP
Hiltz
Hiltz
Michigan
JD 790
thanks peter, ill check that, and thanks for the quick reply
   / 790 starter will not disengage #4
Peter 315
Elite Member
NH
The starter would grind all the time if it stayed engaged .... Do you have any free play it the clutch linkage ?
OP
Hiltz
Hiltz
Michigan
JD 790
yes there is some like more than half of the pedal throw. is it easy to tighten up?
OP
Hiltz
Hiltz
Michigan
JD 790
I need to find my manual. Thanks Peter
   / 790 starter will not disengage #7
Peter 315
Elite Member
NH
Should have about 1 to 1-1/2 inches of free play.... There is a rod that you turn to adjust it just follow the clutch pedal under the tractor..
OP
Hiltz
Hiltz
Michigan
JD 790
Thanks Peter. It has about 1 1/2 inch. Weird but didn't make the noise when I started it up. Ill keep an eye on it. Thanks for all your help, John
