8N key Blanks?
   / 8N key Blanks? #1
Lasgambler
West Coast of Arizona
YANMAR FX42d
Hello, I am having a problem finding key blanks for a Ford 8N. I checked the internet, Ebay and the local hardware stores. Does anyone know of a supplier for these key blanks? Thanks.
   / 8N key Blanks? #2
Did you check your New Holland dealer?
   / 8N key Blanks?
Hi Robert, No I did not think to check a New Holland dealer. I'll try that. Thanks,
   / 8N key Blanks? #4
The originals were all keyed alike. However.. it's very possible you have a tisco repop switch.. or other type of repalced switch.. as the oem ones were a tad 'weak'.. and it's unusual to find one in working order.
That said.. the locks weren't very robust. I had a 2n with an oem key ( switch was bad ).. and I found a short filing cabinet key.. or a cheap garage door lock key could be made to fit using a small needle file set to closely approximate the original key.. as i said.. the locks were not very precision..
Soundguy
   / 8N key Blanks? #5
It's very easy to re-key it with a NAPA switch, it only needs to be a 2 position switch.
   / 8N key Blanks? #6
The echlin will work.. however tisco re-pops a 2 position ford key.. TSC and many other places sell them. heck.. CNH probably sells the tisco key too..
Soundguy
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
