A conundrum on florescent tub lighting for the Jury.
   / A conundrum on florescent tub lighting for the Jury. #11
I have two rows of 8' fluorescents lighting my shop, with four fixtures in each row.
When I started having trouble last year, I also had difficulty finding replacement tubes & ballast.
Rather than convert to LED tubes, I replaced an entire row with new LED fixtures.
I now use the good salvaged parts from the first row to keep the second row working.
When they're used up, I'll replace the second row with LED's and be done with the fluorescents completely.
   / A conundrum on florescent tub lighting for the Jury. #12
I swapped all of my T8/T12's out for led years ago. Very happy. I kept the 4 T5 high bays in the detached shop. They are 20 years old and still going strong.
   / A conundrum on florescent tub lighting for the Jury. #13
In my opinion and experience, LED's work best when they are part of the fixture. The LED bulbs don't last any longer than regular bulbs, if you can find them. And the LED tubes don't last very long either.
I had 8-foot fluorescent lights in my shop, and it was a never-ending job to replace a bulb or deal with one flashing every year. A couple years ago I took them out and ran the Construction String. I'm currently working on converting the shop into a large living room, so I wanted something temporary that provided a lot of light.
Amazon.com
The amount of light I get from this is a lot more than I ever got from the fluorescent lights. I just hung it from the rafters and created an outlet where I cut the line for the fluorescent lights so my 3-way light switches will work.
Before I could work on my shop I had to build a new garage. It's 30 x42 with three 10 foot garage doors. For lighting I went with this LED 12 pack from Amazon.
I installed 2 outlets at the top of the wall that is controlled by the light switch and plugged the first LED light into each one. Then I installed each light to the other in a row across the ceiling. They are 4 feet each and the cord that comes with them is 4 feet long. Two rows of these lights makes it like daylight in there!!!!
   / A conundrum on florescent tub lighting for the Jury. #14
It's very hit/miss. We have some RAB lighting retrofit 8ft LED ballast bypass tubes that were fitted into a bunch of 8ft T12 fluorescent fixtures in various buildings at work. Nearly all of them left on 24/7/365. 5-6yrs later, we haven't lost a single one of them. A lot of other retrofits and full replacement fixtures are absolute junk and can fail randomly and quickly. It's getting worse as time goes on as the electronics that drive these fixtures are built cheaper and cheaper. It's the same fate our fluorescent fixtures suffered. Bulbs were total junk beyond the early 1990s or so. Same with ballasts, etc.
   / A conundrum on florescent tub lighting for the Jury. #15
I replaced two 8ft T12 2-lamp units in our attached garage with these from Menards in late 2023. Compared to 440 watts (4 x 110 watts) usage we are down to 168 watts (4 X 42 watts) now. Instant on-off performance and light quality is superior. Now looking at vapor tight options for our new barn.
It would be about $450 to replace the bulbs with type A (direct replacement)if I did it all at once. I found a replacement ballast for the bad fixture that would cost $44. . My thinking is, all the other fixtures are still working fine. And there is zero noise. To me it seems like a waste to toss out the perfectly good old tubes. And a better strategy to replace with type As, as the older tubes fail. Oddly, there isn't any price difference between the Type As and the non ballast direct wire Type Bs. But the bulbs are not compatible with each other. I already bought 4 of the 8' T12 Type As as replacements for $70. They work but they also stand out with a different Temp rating in the bay. I can swap those for the bench run and then pay attention to the light ratings. None of the local hardware stores had 8' T12 Bypass Type Bs. They only had T8s.
The big x-factor, is am I painting my self into a corner here believing that I can always find replacement ballasts?
An as an aside, the garage has skylights. And the lights are on two switches. There is a smaller bench lighting run, and then there is the bay lighting. I rarely use the bay lighting unless I'm on a project at night. I don't think energy use, in my case is a deciding factor.
   / A conundrum on florescent tub lighting for the Jury. #17
I stupidly bought six or eight 8' dual lamp fixtures before I moved here from the coast because I got a real deal on them, about 1/2 price. I've been putting a cord and pull chain switch on them and putting them on a chain in areas where they only see use for a short period of time. I've been putting 4' LED fixtures where they see more use.
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2011 CATERPILLAR 279C SKID STEER (A52709)
2011 CATERPILLAR...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2014 Kobelco SK500 LC-9 Excavator (A59213)
2014 Kobelco SK500...
2018 DRAGON 53FT FOUR AXLE HEAVY HAUL TRAILER (A58214)
2018 DRAGON 53FT...
2112 (A58376)
2112 (A58376)
