Accidently added some Transmission fluid to my hydraulic fluid.
   / Accidently added some Transmission fluid to my hydraulic fluid. #1
chad22
Veteran Member
Kansas
Sears Garden Tractor
Today I was topping off my hydraulic fluid. I had 1 1 qt bottle of Transmission fluid Dexron Mercon and a 1 qt bottle of hydraulic fluid. Well I accidentally grabbed the wrong bottle and poured a little Transmission fluid into my hydraulic fluid. I caught it before I put even a half a quart in there.
Do you think it will be okay? Because I don't have the money right now for any more hydraulic fluid.
It's just on my home made backhoe. Just wanted to make sure it wouldn't hurt anything or not.
Chad
   / Accidently added some Transmission fluid to my hydraulic fluid. #2
I would go about my business. Many hydraulic systems use automotive transmission fluid as the working fluid. (deere f915 front mower)
Just remember the dexron has a red dye.
   / Accidently added some Transmission fluid to my hydraulic fluid. #3
2x too
   / Accidently added some Transmission fluid to my hydraulic fluid. #4
Been using Dexron-Mercon in my Bobcat Skid Loader for years. It's as good as any hydraulic oil and has seal additives besides.
x3... Forgeraboutit.
   / Accidently added some Transmission fluid to my hydraulic fluid. #5
My Case trencher uses ATF. The alternate fluid is 10W-40 with a qt of Case additives per 10 qt's of motor oil.
   / Accidently added some Transmission fluid to my hydraulic fluid. #6
My 1979 John Deere 312 had ATF in it up until this year when I switched it to Hy-Tran fluid. Just keep on truckin........:thumbsup:
Thanks guys. It puts my mind at ease. I didn't wanna damage anything. Especially after putting a new seal kit in my pump. That seal kit wasn't cheap.
I about had a heart attack when I heard the price. :laughing: "$75.00". But I did save at least $80.00 by getting the seal kit and rebuilding it instead of buying a new pump. So that made me feel better.
I handed the guy the pump. He took one look at it, took it back there and not 2 minutes later he was back with the kit.
Hopefully tomorrow if the weather is nice. I can finally play in the dirt with my backhoe, get to dig up a relatives sewer line for her.
Chad
Mini Skid-Steer Concrete Mixing Bucket (New/Unused) (A59225)
Mini Skid-Steer...
SPRING TOOTH HARROW (A52708)
SPRING TOOTH...
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
550 (A52708)
550 (A52708)
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
