Shawn T. W.
Veteran Member
- Joined
- Jul 14, 2025
- Messages
- 1,441
- Location
- SW Missouri Ozarks
- Tractor
- Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
So a 6-piece stack would be 19 1/2".
But as you said, it is possible.![]()
Good luck in holding them all together until they can get bolted to the wheel?
This is 70 Lbs on my little tractor...
If Kubota sees the drill/modified wheel, will they warranty any rear axle or transmission problems ... ?
Another thought ... On my SCUT with 26" rear tires ... I've added roughly 75 Lbs of WWF and the 3" spacers, and another 70 Lbs of steel wheel weights on each wheel ... Then I added 275 Lbs or dumbbell steel weight plates on the BH frame ... Now I'm not spinning tires to a stop like before ... So the little 25 HP puts full power to the ground, but doesn't have any extra to go around ... My point is the LX has 35" tires, which should on theory provide a bigger ground patch and traction, the little 25 HP engine doesn't need any more weight on it ...
