Adjusting brushhog
   / Adjusting brushhog #1
loopyl
Vermont
I am not really clear on how to set up my brushhog for cutting. This is my second summer of using it and although it does an OK job I feel I don't always have it set properly. The manual is not that helpful and talks about leveling it from side to side and the front being slightly lower than the back. But what about the tailwheel? Should it be riding the ground with slack at the upper link or should it only touch the ground to protect the ground from scalping? Can someone direct me to more detailed setup instructions?
BTW, it is a 6ft Woods rear rotary cutter.
TY
   / Adjusting brushhog #2
This is the way I set mine - going by the bottom edges of the side rails my cutter is very slightly higher in the rear, supported fully by the tailwheel, when I have my 3 pt set to the height I like to cut at (roughly 4"). The tailwheel and the 3 pt arms take the full load of the cutter - the toplink is loose and right at the middle of the 3" slot on the cutter. This slot is what lets the cutter flex up & down on rises & dips, letting the toplink slide back and forth which lets the tailwheel follow the ground. My hydraulic toplink is really handy to adjust this setting on the fly for the severe dips or hills. When cutting extremely tall vegetation I find it's better to kick the rear up more for better discharge - I mostly just kick it up with my toplink instead of adjusting the tailwheel unless it's a large job of tall stuff. If you have a manual toplink it's best to get on level ground and set the deck by eye as described above, leaving the toplink in the center of whatever mechanism you have for the flexing (not all have the slot like mine). Some guys use a chain instead of a toplink to allow the flex. You have to be careful that your flex doesn't go too far either way as to bind or let the pto shaft hit the cutter. I find that with the deck adjusted as I described, I can adjust the height of cut with the 3 pt well within the ranges I like to cut. If it's real dry I'll leave it a little higher cut, maybe as much as 6", sometimes I want a real close cut and can get one with my cutter but you sacrifice some scalping in certain areas to get it. If your land is reasonably flat, you can get as good a cut with your rotary as with a lawn tractor !! Almost forgot - you do need to level from side to side too, one of your 3 pt arm links should be adjustable. Get the deck the same height off the ground side to side using your levelling link. As drawpins bend slightly (or severely !!) sometimes, you need to re-level this adjustment occassionally.
2014 Nissan Pathfinder SUV (A48082)
2014 Nissan...
2002 Hurricane 196FF Fun Deck 19ft Deck Boat with 23ft T/A Boat Trailer (A48082)
2002 Hurricane...
2022 Club Car...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
Super Material Lift MH1000 (A51039)
Super Material...
