Advice 479 Haybine broken wheel axel
   / Advice 479 Haybine broken wheel axel #1
Privatesss
Beaverton, Oregon
Kubota L4310
Here is my problem. May NH 479 Haybine wheel broke off, broke the spindle/ axle inside the wheel hub, trashed the bearing as well.
It appears to be a common issue, but I can't get the spindle/axel out out of the frame. I removed the bolt and pounded both sides. Won't budge. Tried WD40, still not budging. Thought maybe heat to expand the frame?
Not sure which way it comes out. Any advice would be appreciated.
   / Advice 479 Haybine broken wheel axel #2
It'll come out whichever way you can get it to move. Heat it, let it cool. Put a pipe wrench on the stub and get it to turn. LOTS of heat.
Thanks, that's the direction I was headed. Much appreciated!
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
25ft Flat Boat (A56859)
25ft Flat Boat...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2018 Ford F-350 (A55973)
2018 Ford F-350...
