advice needed on new air compressor
   / advice needed on new air compressor #11
I have a Quincy compressor that is very quiet, I can have a conversation standing next to it. Its a 80 gallon 5 hp 220 with baldor motor that runs at 1750 rpm's. You want to look for one that runs 220 at 1750 rpm. i used to have a older sears that was very quiet and smaller 20 gallon still see them on craigslist from time to time. good luck
thanks for all the advice. I've been studying the air tools and it seems that most are in the 5-6cfm range, but a few like sanders and paint guns are in the 10cfm range, so
I'm going to aim for 12cfm or close to it. And while I thought I'd like to stick with a 110V unit, they don't produce the power needed. Which brings me to my biggest concern. Hidden in a few
tool specs are the terms "average consumption". One said 5cfm average but a whopping 12 cfm at full load. So I wonder if the specs usually given are just "average". So does one's 600 pound torque impact
wrench only put out 400 trying to get a frozen bolt off? Seems to suggest that going a little larger here makes the most sense, which means at least a 3.5hp motor, and likely a 5. So I'm looking in the range of 3.5hp with a 60 gallon tank to 5hp with a 80 gallon.
I like the Quincy line, all US made, though I wonder if their least expensive stuff still is, since they have a factory in China now, which may only be for local consumption there. Quincy and a few others make super expensive air compressors for hospitals and industrial use, so I think any company that knows how to build very high quality equipment must have some trickle down high standards they apply to their lesser spec equipment, assuming they just don't offshore production. And then, I'm sure, there are good Chinese air compressors, but part of me still wants my money to stay "at home". I had two of my next door neighbors laid off three years ago when the economy took a dive, and it made a real impression on me. So I'm sure I'll pay 20-30% more, but if that's only a couple hundred bucks, spread out over the next twenty years, I'm willing to do it. The Puma compressors also looked nice, and I'm sure there are Ingersoll Rand and Campbell Hausfield units that would do ok too. So I'll study cfm and db ratings and go eyeball the units at the box stores just to educate myself. Frankly they all look pretty similar. And I've read enough blogs where units melted their plastic covers from overheating so I think the enclosure idea is out. Though the bigger ones are all metal, the cooling problem remains.
so far this one looks most promising to me, and seems reasonably priced: http://www.northerntool.com/shop/tools/product_200479713_200479713
   / advice needed on new air compressor #13
I have a single stage 60 gallon upright 5 hp compressor. This is too light for what I really use. I have to wait for the pressure to build back up.. If you can afford it. I would get a 2 stage compressor which will handle the torque you want on your air gun. minimum of 5 hp, but. better with a bit higher hp compressor motor... Try TP Tools website, they carry Quincy and IR compressors.. TSC carries IR compressors.. just to name a few places to search..
Good luck with your search.
Tom
I'm always looking for reasons to take a drive to TSC, one of my favorite places, so I'll check them out. Thanks
   / advice needed on new air compressor #15
Why would you want their disposable line. Also IR makes nice compressor but TSC carries their lower line that run at high RPMs and have smaller pumps. If your looking for inexpensive unit find a used one that runs at 220. Oh have you considered the IR TI 2135 Impact gun its got loads of power for such a small unit.
   / advice needed on new air compressor #16
If you want a good compressor, for one man to be able to work using a sander for any length of time, you will need a minimum of 12-14 cfm @ 90 psi. Anything less than that, and you either going to have to use the sander at really low speeds, or intermittently.
While 12-14 cfm will allow continuous operation of a DA sander, it will require the pump to run continuously, which will have the potential to make lots of heat, and water, especially in warm weather. This can require additional expense to deal with.
The higher pressure compressors are more desirable, but 150psi is enough.
Don't go all in on one just because it has a big tank, that is not paramount. You are going to be running off the pump for continuous service, if it can't keep up, the tank size won't matter much.
   / advice needed on new air compressor #17
yep.. ditto that. and remember. a unit that is 150 psi vs a 120 psi the 150 is giving you really.. alot more air.. especially if you are using it at say.. 90..
onthe paint gun.. figure that as intermittant use. you rarely are paingin witht he trigger pulled 100% of the time.
same on a big air wrench. the tank will carry thru most laods.
now.. stuff like sandblaster and sander or an air drill.
oce you use down to the cut in.. it's all compressor... thus a 2 stage is usually nicer.. if you need it.
soundguy
I don't...
Interesting that Quincy shows two pump specs, the lesser line at 10,000 hours and the "pro" line at 50,000 hours.
If one runs a compressor ten hours a week, allegedly the cheaper unit should last 19 years. That's better than disposable, but run it
20 hours a week and now we're under ten years. The challenge of course is cost; doubles in price to get the better grade, mostly equivalent compressor.
For my application, not sure I need the "better" unit, but no matter what, I need enough cfm.
Also interesting that I've seen some double cylinder single stage units, but most, if not all, 2 stage units are double cylinder.
My friend and I both bought HF one ton hydraulic lifts to pick up our mowers and equipment. Mine has worked fine. His let go on him recently while he was underneath, apparently because
he turned the valve too tight and it failed. Scary. The lifts look identical to the Torin units, maybe a Chinese copy of a Chinese unit. I always use jack stands, but as always,
one gets what one pays for. I don't see any dangers from a compressor, but another life lesson that less is rarely more. But I also don't need a rotary screw compressor for sure.
   / advice needed on new air compressor #19
I don't...
With Quincy and other better compressors, I will bet you also get a heavier gauge tank on the better units.
Hold on to one long enough, and you could find out why that matters. A lot of these compressors today, are throw-a-ways, not designed to last for decades. If you don't use it enough to wear out the pump, you could end up down the road with a rotted tank.
Even if you are diligent about draining condensation, you can still get a tank that has a spot that stays just wet enough, to eventually rust through. So, the thicker the better. (Except when you have to move it.) :D
   / advice needed on new air compressor #20
I have a Speedaire 5hp single stage 60 gallon compressor. It's an older model that doesn't have a filter on the intake. It's enough for doing most anything I want to do but I have always wanted to upgrade to a 10hp (single phase) Quincy. I have no problems running an AirCat 1/2" impact wrench or painting. There's enough breaks while doing those tasks that it can easily reach full pressure and shut off. But if I start doing things like sanding then it runs continuously. The AirCat impact is extremely quiet and is about as powerful as you can get in a 1/2" drive.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2008 Dodge Ram...
8' Avalanche Snowbox (A55272)
8' Avalanche...
2339 (A58376)
2339 (A58376)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
2022 CATERPILLAR 259D3 SKID STEER (A52709)
2022 CATERPILLAR...
