Tinhack
Elite Member
- Joined
- Jul 3, 2020
- Messages
- 3,467
- Location
- Lytle, TX
- Tractor
- Ford 3910, John Deere 420C, Kubota G32XKS, IH 2606, Bad Boy Maverick-60"
^^^^ This right there.To work, these require that the air coming out of the compressor has cooled enough for the water suspended in the air to condense when it hits the mesh. Those mounting it directly to the compressor usually end up with water in their lines, because the compressor tank gets hot and thus the air passing thru the separator is too hot to allow for condensation.
Unless you have a cooler/dryer, you want those inline separators away from the tank to allow the air to cool and condense the moisture. This is also why iron pipe is a bad choice for lines--They rust from the inside out.
I have a forced-air cooler right after the tank and above it. It turns on when I turn on the compressor. The cooler runs all the time while the compressor cycles as needed. Condensate drains back into the tank and out the bottom drain--Basically, a metering valve. It bleeds all the time. My inline filters and separators are always dry. And that means dry air.
