"Alternator Kit"
   / "Alternator Kit" #11
/pine,
If you want to add lights, consider a couple of LED lights. I had a 55 watt halogen on my BX23, and when that burned out I put on an LED from Northern Tool. From what I see it is every bit as bright and uses very little amperage. It is also a much whiter light. Someone said in a different thread that it uses 12 watts, but I can't say for sure. If you want the inverter, well that's another story. You could easily use multiple lights without draining the battery. Here's a link to the light:
Buyers DC LED Utility Light — 12 Volt | Work Lights | Northern Tool + Equipment
   / "Alternator Kit" #12
/pine
If you're the one who got the kit will you post the alternator number. I've looked and see a bunch that look like the one in the kit, many are listed as Nippondenso/Kubota.
(2) Heavy Duty Tow Straps (A50860)
(2) Heavy Duty Tow...
2018 Ford Fiesta SE Sedan (A48082)
2018 Ford Fiesta...
2018 Mitsubishi Mirage ES 4D Hatchback (A50860)
2018 Mitsubishi...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A50860)
UNUSED Grey...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
