FTG-05
Elite Member
- Joined
- Jan 7, 2011
- Messages
- 2,588
- Location
- TN
- Tractor
- Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
Since the repairs on my 286 bushhog are so much more involved than I originally thought, I decided to start a new thread. It really isn't necessary to start with the other thread, but if you want to refresh your memory, here it is: https://www.tractorbynet.com/forums/attachments/410436-oh-joy-time-replace-bushing.html
So I finally received the 46mm socket to take off the M30x2 nut so I could remove the Pan Weldment and Blade Bar. My Milwaukee 1/2 M18 Fuel Impact had no problem taking off the nut (no surprise there since the blade bar was loose); everything came right off.
What I found was not encouraging.
Pics tell the story better than I could. But basically, there's a keyed shaft with a corresponding keyed blade bar, fastened together with the above noted M30x2 castle nut. Both had at some point in the past slipped/sheared and both were just spinning against each other.
Pics:
Output Shaft end:
Output Shaft closeup:
Blade Bar, downside (further from gearbox):
Blade Bar, near side to gearbox:
Blade Bar closeup:
Bottom line: There is nothing between the Gearbox Output Shaft and the Blade Bar to keep them from spinning against each other.
Discussion of Options to repair to follow.
Thanks for looking!
Pics:
Output Shaft end:
Blade Bar closeup:
Thanks for looking!
