Another Rooting Bucket!
   / Another Rooting Bucket! #1
Gfranklin
NC
JD 870
Here is a picture of the bucket I just finished building. Randy's earlier post under "Shrub Removal Bucket" got me motivated. I had a friend shear the metal out for me. My tractor is 28 hp and my fathers 1070 is 38 hp I believe so I stepped up the plate thickness to 5/16" except for the large backplate which is 1/4". The two 6" channels were already on hand. I decided to add some stiffeners to the bucket edges and make it heavy duty since I wasn't sure how this thing would end up working so I made it heavy duty. I added a hook and later realized it may help out as a visual centerline reference when positioning the bucket.
   / Another Rooting Bucket! #2
Very Nice, I would love to build one if I could ever get my pole barn finished. Lets see some action shots!
This shows the JD method of quick attach. I had talked earlier about my concern with welding the pin on because it is turned down to 3/4" and welded on one side only. This bucket was aggressively used in both curl and dump and no problems here.
This is a direct side on shot showing that the bottom and the back are not at 90 degrees. I did not have any plans except for Randy's picture so I originally made it 90 degrees. I then became aware that the bucket wouldn't curl to level at ground level so I torched it down to about 75 degrees. This worked as we'll see in the next pictures.
Here the bucket is sitting on the ground and at maximum curl the bucket is sitting perfectly level. This is more coincidence than anything but seems like a good target parameter in hindsight.
   / Another Rooting Bucket! #6
Geepers...just don't catch anyone's ankle (or any other body part) with that toothed monster! (Nice job on the bucket)
Here is maximum dump. Seems like 75 degrees works. One of the first projects was burying some roadkill and this dug a deep hole quickly. Covering up was done by switching buckets.
A direct head on shot. All my angles and dimensions were guestimates.
I took a torch and a grinder and knife-edged the steel between the teeth. This helped somewhat with root cutting and tree grabbing.
Let me apologize for not having any action shots at the present. The camera got seperated from me at the worst time. The bucket is at my fathers and the family got him a digital camera for Christmas. I will get him to take some pictures for me as his homework project!
He got to use it for about 1.5 hours while I watched and I got in about 10 minutes. We knew the breakout force would be significantly affected because of the long bucket length. The botton plate is exactly 30" long and the teeth added at least 6 inches. Curl alone will rip out a one inch diameter tree and an 1.5" tree depending on soil, species etc. 3" and 4" diameter trees were pushed over by forking them about 4 feet off the ground and then going after the roots. My turn came on the last half of a 10" diameter stump. It took 3 to 4 different directions of attack and a certain amount of digging at the roots.
One of the techniques was to get a good purchase on a root and then dumping the bucket while driving forward. This usually just made the teeth slide backwards in the ground but sometimes it would snap a 2" diameter root as the bucket "rolled over".
What seemed most effective was a combination of roll and dump coupled with forward motion of the tractor. Traction dictated the effectiveness of this. The ground was wet but not necessarily muddy and traction was generally acceptable. We did leave lots of tire holes though.
We haven't got much time on it yet but I am generally pleased. The stump was wrestled right smartly with the FEL before giving up and abandoning it. This is what motivated me to make this bucket. Twenty minutes with this new bucket and the stump was out so it is definately a success.
There was absolutely no indications that anything was undersized. I saw no flexing or anything else out of the ordinary.
The only thing I might change is the overall length which is right at 36" including teeth. Any length left off here definately increases the breakout force and you'll never have enough of this. This length did dig a deep hole for the animal carcass though. I am thinking at least 8" off this but I haven't used it enough to be sure. I am thinking about torching out this 8" or so by cutting the bucket off clean at the backplate and welding it back on less the 8".
We cleared out about two dozen 3/4" dia trees, a dozen 1 to 2" dia trees and a half dozen 3-4" dia trees all in about an hour.
I would be glad to give any dimensions if interested.
Greg
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2016 Ford Explorer SUV (A50860)
2016 Ford Explorer...
2016 Cadillac ATS Sedan (A48082)
2016 Cadillac ATS...
UNUSED Hook & Eye Turnbuckle Set (A50860)
UNUSED Hook & Eye...
Toolbox (A50860)
Toolbox (A50860)
Quick Cool Camper A/C Unit (A50860)
Quick Cool Camper...
