Antifreeze (again)
   / Antifreeze (again) #1
MiserableOldFart
Platinum Member
Delaware County Catskills NY
NH Workmaster 40, Kubota GR2120
OK, it's that time of year, and as every year at this time, I dutifully drain, flush and replace the coolant. The dealer where I bought my tractor is no longer in the New Holland business, and the one where I buy parts sells a generic green antifreeze.
After reading so much about the disasters of antifreeze on this site, I decided that this year I would go out and find something made especially for diesels, so I went to the local auto parts store and got Zerex Heavy duty diesel ready 300,000 mile, 7000 hour guaranteed premix. I had previously purchased a gallon of Sierra, but was scared off from using it by the many posts about the dangers of antifreeze in tractors. The Zerex doesn't specifically mention CNH, but does say it meets the standards of CAT and John Deere, so I'm thinking this is good stuff. Is there anything wrong with this logic?
And once again, I have to say, that even though I do it, the antifreeze I take out of the tractor at the end of 12 months and about 50 - 60 hours looks as good as it went going in. I just can't believe it's necessary to change it this often, but I do it because the owner's manual says to. Anyone out there who stretches their coolant? I'm not talking about 7000 hours here, but I do truly believe that it would easily last 36 months and, say, 200 hours without losing its ability to protect the engine as well as prevent freezing... but, I don't believe it enough to not change it every year..
   / Antifreeze (again) #2
Your tractor should have 50-50 winter/summer permanent anti-freeze. Don't let the discussions and horror stories of cavitation bubbles bother you. All those things apply to wet sleeve diesel cylinders only. Your cylinders are dry sleeve and nothing like those others. Ethylene Glycol permanent anti-freeze is what you should be using. If you feel really worried about leakage and the environment, you can use propylene glycol antifreeze instead. The only advantage of your using anti-freeze with diesel additives goes into the pockets of those selling anti-freeze. Please look at your owner's manual and consider that NH has recommended normal anti-freeze. They also recommend an annual change based on farm tractors with hundreds more hours of use each year than you will use your tractor. I think you could safely change your antifreeze at the same time as you change hydraulic fluid. That's at 300 hours. If you change each 300 hours, you'll probably see that even then you'll wonder if you aren't pouring out perfectly good anti-freeze. Whatever you use, test it to make sure you have the proper freeze protection before winter's chill hits.:thumbsup:
   / Antifreeze (again) #3
Like yourself, I also only put 40-60 hours on my tractor every year. I have a 2 year change schedule. One year is just too soon with so few hours. NH is being safe when they say yearly because they don't mention hours. I would think the yearly change is meant for the 250-500+ hour per year types. My dealer said most people don't change their fluid at all or maybe once every 5-6 years..if the tractor is lucky... so our tractors are way ahead at every 2 years.
Also remember to only use distilled water. Never use any radiator flush chemicals. The harsh chemicals peel off the protective coatings on the aluminum radiators.
I use regular Prestone green anti-freeze with the New Holland FW-15 conditioner and test it with the Fleetguard strips once or twice per year.
   / Antifreeze (again) #4
Don't let the discussions and horror stories of cavitation bubbles bother you. All those things apply to wet sleeve diesel cylinders only. Your cylinders are dry sleeve and nothing like those others. Ethylene Glycol permanent anti-freeze is what you should be using. :
I'm going to disagree with you on this one. I have 3 NH dealers within an hour of my house and all 3 have said to use a diesel conditioner even though I have a dry liner engine. Ford had cavitation problems with their dry liner tractor engines back in the 80's and 90's so it happens.
There was also a diesel tractor engine rebuilder on a Kubota thread?? on TBN that said they do see damage in the water jackets on dry liner engines from cavitation and he makes sure he runs it in his dry liner engine.
   / Antifreeze (again) #5
the fw or fp 15 is only a few bucks a pint.. not a big deal to add it even if not needed.
soundguy
   / Antifreeze (again) #6
What does your owner's manual call for? Read what it says and repeat over and over to yourself, "The dealer sells additives. He makes more money from me when I buy them." Do what you want. . . it's your money.;) As for me, anecdotes with no evidence are just fiction. What model tractor engines?
Why is it that 80s and 90s Fords don't have problems unless somebody brings it up in an anti-freeze discussion? I never hear anyone say, "Oh don't buy 80s and 90s Fords, they had water jacket damage.":rolleyes: I think it's just another urban legend. Too bad Snopes doesn't debunk tractor rumors.:) Nothing against any of you personally, but you are being sucked in without concrete evidence. For me, when you go against manufacturer's recommendations, you have to show me. I'm from Missouri. . .
   / Antifreeze (again) #7
My NH TD95D manual recommends coolant with a DCA in it (A Fleetguard product). I just changed out my antifreeze with Prestone Long Life coolant and I added a pint of Motorcraft DCA. My Ford 4610 has wet sleeves and I have been using DCA in it for many years even though it's not in the owners manual recommendations.
   / Antifreeze (again) #8
Yes, your TD95D recommends coolant with DCA and your 4610 is wet sleeve. If that were the case on the TC26D of the OP or my TC45D, I would never have posted my opposition. There are additives you need in the coolant of an engine with an aluminum block that you don't need in a cast iron block engine. To suggest you can gain any advantage using those additive on cast iron would also bring on my doubts. If you walk into any autoparts store or even Walmart, you will find shelves full of additives for everything in the world. None of them are terribly expensive, but the the sales of them to hundreds of thousands of folks makes a lot of money.
BTW: Did you hear recently that they are saying multi-vitamins are of no real use to most people who take them regularly? Now, I don't know for sure. . . just sayin'. ;)
   / Antifreeze (again) #9
I am positive this is not the correct thing to do and my tractors were both vintage Ford gasoline 4 cylinder engines. I never changed coolant in my tractors.:ashamed: I did check it regularly, but never changed it.:p One of them I had for over 10 years. Yes, yes, yes, I know now that this was not the right thing to do.:( For the most part the Ford 2000 stayed outside..summer and winter. The 641 was kept inside because it was a beauty and I would go to the trouble of pulling the mower to get her in my shed. But I only owned the 641 for two years. I did grease it often and change the oil twice a year. Cleaned all filters regularly, etc, etc. But I never had a problem. I believe I will follow the 300 hour rule. It just got changed by the previous owner at 300 hours and it is still under 350. I don't want to start a war on coolant changes but I wanted to share my experience. Certainly not as a model of what to do. Did I mention I live in Northeast Kansas...it does get COLD.
   / Antifreeze (again) #10
it's got to be better than the 'clean pond water' they would have got back in 39 :)
soundguy
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
