Any Issues Using Other Peoples/ Rental Attachments?
   / Any Issues Using Other Peoples/ Rental Attachments? #1
curtisfarmer
Southern NH
M7040, L48, KX121-3, RTV 1100 and a couple of older Fords
Are there problems mixing fluids among machines, aka Bobcat or other machines which are non-super UDT. I am weighing rear remotes on the new L48 which I have no Hyd. attachments for (yet) and want to know if I should even consider contaminating my machines with other fluids. Changing the fluid and filters in the L48 is around $400+.
   / Any Issues Using Other Peoples/ Rental Attachments? #2
You don't know what kind of maintenance or what kind of fluids are used when maint is eventually done. I personally would not risk my machine by using hydro attachments that I did not know the history on. Just my opinion
My concern exactly, don't want to pollute my machine like a junkie with a dirty needle.
   / Any Issues Using Other Peoples/ Rental Attachments? #4
I've seen a few people say hook up, put the return line in a bucket, flush it a bit and add makeup fluid to your unit. If you HAVE to use a rental unit that's probably the thing to do.
   / Any Issues Using Other Peoples/ Rental Attachments? #5
Thats a good idea if you don't mind paying for the extra fluid and basically servicing the rental unit. :rolleyes:
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2007 Ford Crown Victoria Sedan (A50860)
2007 Ford Crown...
2000 Ford F150 (A49461)
2000 Ford F150...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
