any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #431
tHANK YOU MUCH - aGAIN. Dang Caps Lock always gets my fat fingers.
I would urge everybody to check their rear axle bushings and the deck arm bushings.
From what I read, they should be checked every 500 hours. If you let them go until the pins and important parts are wore. It's a much more time consuming fix than just swapping the brass bushings.
   / any toro groundsmaster fans on here? #432
1otP0
   / any toro groundsmaster fans on here? #434
Just saw this thread...
I'm traveling 85 miles tomorrow to look at a 325D...
I hope to bring it home...
Here are the pics...
Owner states 455 hours and A+++ shape...
Any input would be appreciated...
Did you end up buying this one? I noticed it was still listed.
   / any toro groundsmaster fans on here? #435
I was negligent in greasing the bearings on the back wheels of the 233D.
The bearings spun just enough for there to be perceptible wear in one spot on the spindle - inside bearing - right side.
What are my options? Or should I just throw it together and go?
On 10 acres, those little wheels go round and round - a lot
I peened each spot with a center punch in 4 places. Tightened the bearing right up. It still slides on and off easy enough.
I actually had to file my peen marks a tiny bit
   / any toro groundsmaster fans on here? #436
Sounds like a good fix to me. :thumbsup:
   / any toro groundsmaster fans on here? #437
Yes...
I've used it now for several months...
Need to get a fuel sending unit and a new hour meter...
Purchased some spacers to raise the deck and a couple of used weights...
Had to get a cap for the deck adjustment that sits on top of the spindle...
Darn thing has the spring and spacer built in that uses a circle clip...
Eventually just sit the spring in it without the circle clip...
May just put a pin through the next one...
It is a great mowing machine...
No trimming involved with the 6 foot deck...
It's offset to the right about a foot or so...
My yard has never looked better...
They have a great deck and the Mitsubishi diesel is a fuel miser...
   / any toro groundsmaster fans on here? #438
Yes sir! Just saw your post for the first time and instantly became a member
   / any toro groundsmaster fans on here? #439
:welcome: to TractorByNet! :thumbsup:
Post some pictures please.
(12) TOPPING JARS (A58374)
(12) TOPPING JARS...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Year: 2024 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A56859)
Year: 2024 Make...
