Anyone doing anything with their 24DA?
   / Anyone doing anything with their 24DA? #11
Just did a little touch-up work on our private road to make it wider, then started the switch over to winter gear. I stuff the rear blower on a large pallet in my shed for summer storage, quite the shoe horn job that requires removal of the FEL just to get the tractor turned inside. Now the MMM rests in there for the winter, safely chained and blocked to the wall.
Also welded up some brackets for shoes on my rear blade, can't wait to try them. Still no snow this year, story of my life in the 3 years and 346 hours (had to go check!) I've had the machine. Need to put the chains on today.
Other than that, its just a firewood mover and garbage can transporter this time of year. Gives my son good practice on the machine and the neighbor pays him well for the garbage can return each week.
Keep your fingers crossed for tons of snow!!!!
Brad
   / Anyone doing anything with their 24DA? #12
This thread inspired me yesterday. I did go out and start the tractor. Took the MMM off and rolled it back into the garage - had to back it out to take it off as too much stuff has migrated into the garage.:( I then put the rear blade on. I believe I'm ready for the snow. Though I still didn't get the MMM cleaned. It is also due for an oil change, hydraulic fluid change, and antifreeze change as I'm at 667 hours. I will probably just wait until spring and do it all. There will probably only be 2 hours put on it between now and the first mowing. Now if we start getting a bunch of snow and I start putting a bunch of hours on I'll go ahead and do it all. I know, I should've already changed it so the engine doesn't "sit" with dirty oil in it.:eek: When I do all of this, I need to get a couple of items for the MMM as well that need to be fixed/replaced.
   / Anyone doing anything with their 24DA? #13
Well here is something new you could use your tractor for! ;) I just stumbled on that and just can't resist to post it. LOL :-D
Its a lil video.
YouTube - Tractor drifting in snow
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
